SC10 Thread
#4276
Hi just got back into rc ,got a strike losie first thing i did replace moter with venom brushless 13 turn 35a with esc pack , $ 150. Then 2 nimh 8.4 venom battery$ 60 each it goes quite well for under $ 500 ready to run. Raced a $ 2400 car and won 2-3 times , just goes to show power dosent win races.But its more fun .
#4277
#4278
#4279
I really got my SC10 dialed in this weekend. It was horrible before, I just could not keep the back end from going bananas. I'm sure I can get it dialed in even better but here is what I did:
Replaced rear tires with Pro-Line Caliber's
removed the spacers from the front springs
Flipped the battery strap upside down and slid the battery all the way back against the shock tower. Going to get the factory-team battery strap here soon.
The tires alone made a lot of improvement but it was still squirrely. The combination of the tires and the battery movement was pure love juice.
Last night after a tear-down for cleaning. I put 30 degree blocks on the front and I think I'm going to replace the springs with the factory team setup of red in front and grey in the rear.
Some guys are putting an additional 3 degrees of toe on the rear but I'm going to hold off on that until I see how the 30 degree bocks do then see how the springs do.
#4280
#4281
It's the RTR stock oil, I believe it's 30wt. I'm considering getting the VM2 factory team shocks next month.
I'm loving this truck. I've only raced against Blitzes and Slashes but stock setup, the SC10 just owns them but you REALLY have to set up the SC10, right out of the box it blows on dirt but is great on pavement or carpet.
#4288
Hey guys I'm running a Ballistic 8.5 in my SC10 with an 87T spur. Novak recommends a 10.5 FDR with an 8.5 motor which comes out to about a 22T pinion which I don't believe will fit. Whats everyone else running with this motor.
