SC10 Thread
Old 12-05-2009 | 12:35 PM
  #3526
z50king's Avatar
Originally Posted by revracr909
Some FT T4 shocks would be nice, but matt runs xxx-nt or t threaded shocks.
xxx-nt or xxx-t shock, thankyou. i asked him a few times but he bought the shocks on ebay and couldnt tell me what they came off of. i found a few sets on ebay
z50king is offline
Old 12-05-2009 | 07:29 PM
  #3527
Gilley11's Avatar
Got a little Captain in ya??
Originally Posted by SC10 Rookie
i tried the slash conversion hub kit and ended up having too much offset to the point where it had dramatically reduced steering. it was terrible. I suggest you get some newer AE rims(they are thicker than the old ones, get a couple of washers one for each side so the nut doesn't bottom out) or the Jconcepts.
Ya I've noticed alot of bind with the stock axle spacer and drive pin. Seems the backspacing of the rim as it seets into yhe axle pin puts pressure on the bearings reducing wheel spin. Thats the main reason reason I was wondering about the 12mm hubs
Gilley11 is offline
Old 12-06-2009 | 12:18 AM
  #3528
dandrat's Avatar
add weight and/or get losi 2 degree hub part no. 9808
im reluctant to use anything losi but i suppose i will give it a shot anyway.
thanks
dandrat is offline
Old 12-06-2009 | 12:51 AM
  #3529
Do all of the 4 companys rims interchange? Like can the slash rims fit on the sc10 vise versa?
DeputyDad78 is offline
Old 12-06-2009 | 04:10 AM
  #3530
balistic's Avatar
NO, AE is there own world, Traxxas is different front to rear and 12 mm, HPI is nearly the same as Slash rears, OFNA Hyper10 are 1mm less offset than slash rears/HPI's. I haven't measured Losi wheels but they are 12MM too.
balistic is offline
Old 12-06-2009 | 08:30 AM
  #3531
Damnit, I really like a set of Slash wheels and can't seem to find them specifically for sc10.
Old 12-06-2009 | 12:56 PM
  #3532
thanks
I've been running them since I built my kit. Got plenty of races on them. I run 8.5 brushless so I needed the truck to track straight under hard accel. I'd pick up 2 sets just in case, but I haven't cracked/broken mine yet and I've side swiped the wall and some trucks plenty. Also, I added 3 oz. in the rear and 1.5 oz. in the front. That's just what I did, add .5 oz. at a time and see what that does for you until you get it dialed the way you want.
SC10 Rookie is offline
Old 12-06-2009 | 01:58 PM
  #3533
tennvol11's Avatar
Has anyone used boca's orange sealed ceramic bearings on a build, and how big of a difference was noticed?
tennvol11 is offline
Old 12-06-2009 | 04:15 PM
  #3534
offtraxx's Avatar
I use the yellow seal ceramic hybrid in my 10.5 motor. well worth the $15 each. not had a problem since
offtraxx is offline
Old 12-06-2009 | 07:34 PM
  #3535
Default What a PAIN in the butt to clean
Track wasn't as dry as we thought
Old 12-06-2009 | 08:34 PM
  #3536
Wow!!
SikKustomz is offline
Old 12-07-2009 | 08:27 AM
  #3537
trdsupra88's Avatar
Deputy...I found a sweet mod to keep most of the inside dry...I used an old b4 body as a undertray...now that I am putting it into words I just remembered that Jconcepts has one out...Ill post pics if I can remember...
trdsupra88 is offline
Old 12-07-2009 | 11:39 AM
  #3538
RcRacing4Ever's Avatar
Default GOT DIRT?
this was only after 1 qualifer & 2 more togo with the race...lol
thank you Jconcepets for coming out with a cover...lol
Attached Thumbnails SC10 Thread-dirty-truck.jpg   SC10 Thread-1-dirty-truck.jpg
RcRacing4Ever is offline
Old 12-07-2009 | 11:59 AM
  #3539
ZiG-87's Avatar
ZiG-87 is offline
Old 12-07-2009 | 12:14 PM
  #3540
revracr909's Avatar
Im almost sure there off a xxx-nt Ad2/Mf2 from the looks, but could be wrong. I would look at his shocks again next time and match them up and see what they are.
revracr909 is offline
