SC10 Thread
Old 05-08-2012 | 09:42 AM
  #11776
Brushless420's Avatar
Default servo
Originally Posted by Lake Ober
A quick question for you guys:
When I first built my F.T. back in December of last year, I installed the Savox-0252MG servo in it, with a Spektrum "glitch buster" --> This One After installing this setup, I never had any issues with glitching or brown-outs.
Recently, I decided I wanted a faster servo, and picked up an infamous Savox-1258TG. After installing it, along with my Spektrum "glitch buster", I keep getting a "glitching" sound from the servo (even when it is on, but at rest). There is no twitching going on, but just noises. I am assuming this is now occurring b/c this servo draws a larger amount of power then my previous one. So, should I pick up a Castle external BEC --> This One to solve this problem?
Also, if I do need the Castle BEC, what output voltage should I set it at with my CastleLink... 5V? Any knowledge would be appreciated. Thanks
Yep, I agree, it is expensive. That is one of the main reasons, why when someone asks what kind of SC10 they should get, the RS or the Factory Team, I would typically suggest the F.T. Unless someone is very young and just planning to play around with it, the F.T. will cost more up front, but will give you a truck that you can use even at a professional level. I mean, R/C is something that people usually start doing just to see what it's like, and end up loving it, and wanting to move on to better stuff. The F.T. kit not only allows you to build it exactly how you want it (and forces you to learn the in's and out's of your truck), but also has many upgraded parts that will help with the overall performance of the truck.
All those Savox servos are digital and make that sound. Has nothing to do with the current draw from the servo. No worries. If you want to get away from worrying about your servos draw dump that Castle MMP and get a Tekin RS or RS Pro. The BEC is crap in those Castle ESCs. Have used both and the Tekin is a much better ESC all the way around. There isnt a servo out there that will brownout with the Tekin.
Brushless420 is offline
Old 05-08-2012 | 09:51 AM
  #11777
Mizchief's Avatar
Yes, the Avid hex adapters that everyone is talking about on here will work great for you --> http://www.avidrc.com/product/5/acce...ccesories.html. You can run the RS wheels on them, and it will not change your width. Also, JConcept makes aluminum hex adapters (wouldn't recommend at all), and AE make plastic hex adapters (the same ones that are on the RS) which are a bit cheaper then the aluminum ones --> http://www.amainhobbies.com/product_...ter-Set-SC10RS. If I were you, I would just go with the Avid ones, only $17 for all four of em', and they sound very promising
As far as the shocks go, the ones on the F.T. truck are significantly better then the shocks that come stock on the RS version. The F.T. shocks are V2's and are threaded (for easier adjustments), and have bleeder caps on them (for simple shock bleeding). In addition, they are very easy to build. Many owners of the SC10RS will often install the V2 shocks on their trucks because they are a very useful upgrade. Here is the product listing, just incase your interested:
Fronts:
http://www.amainhobbies.com/product_...ront-Shock-Kit
Rears:
http://www.amainhobbies.com/product_...Rear-Shock-Kit
Yea the bleeder caps are a must on this truck if you want air free shocks. Since there is no bladder and the seal is on bottom of the tread its a real PITA to get all the air bubbles out with the stock or Al caps.
Mizchief is offline
Old 05-08-2012 | 10:47 AM
  #11778
Lake Ober's Avatar
Originally Posted by J_Bone
With a MMP you should always use the BEC. You don't need to set the actual ESC voltage since it wont power anything. Set the BEC voltage to what you need for RX and servo.
Thanks for the help guys! However, it sill seems like I'm getting a few different answers. @Brushless420: Are you saying that the Savox-1258TG is going to make that noise regardless if I use the Castle BEC or not? (Also, I will keep that in mind about the Tekin ESC's when I go to build my next R/C vehicle. I very well might pick up one then, I've heard great stuff about them.)
@J_Bone: Do you have a MMP installed in you SC10, with a Castle BEC, and the Savox-1258TG? Does it make any "glitching" noise at all? I know a few guys at my track have the 1258TG servo installed, and it doesn't make any noises (if I recall correctly).
Does anyone else on here have a MMP, Savox-1258TG, and a Castle BEC installed on their trucks? Does your servo make any "glitching" noises, or is it silent while operating and while at rest?
Lake Ober is offline
Old 05-08-2012 | 10:53 AM
  #11779
Originally Posted by vfrninja
I run 7k in mine on a high bite technical track and It's real close to the feel of a tight ball diff. I put a very small bead if silicone rtv around the gasket and it doesn't leak a drop. If it leaks around the outdrive replace the orings and grease them up good when you install them. You can use black grease or I prefer green (teflon) grease. I've gone between both diffs in this and other vehicles and prefer the gear diff because I feel its more durable.
What does rtv stand for? Is green grease the same as ae green slime? Thanks
Murray100 is offline
Old 05-08-2012 | 10:56 AM
  #11780
jlfx car audio's Avatar
Originally Posted by jlfx car audio
it was origionaly a std kit that been fitted to 85% ft parts. when i was told by seller and the list,which i cant remember was all the main stuff. it has the ball diff and i prefer the ball diff tried gear diffs on road and only like them up front with thick oil so since this is a 2wd i stick to the ball diff. i have purchased the mip diff and carbide ball to insure i have a good diff avaiable it seller didnt keep his up to snuff. it dont have the conversion hexes up front . does this matter since my other truck i race is the losi scte4x4?
going to be running a novak 8.5 and gtb in it lookin to gear it to a 18/81 i think.we have 2 different tracks we race a 1/8th scale large jump track that hardpacked w/ loose sand out of grove, other is intended for SC realy bumpy small bumps/jumps track stays moist and it hard loomy dirt
My q was lost jn the show and tell so let me ask again
jlfx car audio is offline
Old 05-08-2012 | 11:01 AM
  #11781
J_Bone's Avatar
I no longer have a MMP esc, I went Novak. But the MMP did make my airtronics servo noisy as well. Since switching its not so noisy. It still makes a noise but nothinging like before.
J_Bone is offline
Old 05-08-2012 | 11:06 AM
  #11782
J_Bone's Avatar
Yes , hexes are better. They are cheap to convert though. I don't see how your other truck matters to hexes up front on a SC10.
J_Bone is offline
Old 05-08-2012 | 11:28 AM
  #11783
RTV is a type of silicone. It is used for lots of different things, mainly on automobiles to seal up thermostat housings, manual transmissions, stuff like that. You can find it at any local parts store or wal mart. I always like the black RTV. When you use it don't glob and cake it on, a thin layer will do just fine. I had to rebuild the 6 speed transmission on my drag car because the previous owner used too much RTV and it mashed out inside of the transmission and ended up getting in the bearings and also behind the shims. Here is a link to what RTV is
http://www.permatex.com/products/aut...sket_maker.htm
cody161 is offline
Old 05-08-2012 | 11:47 AM
  #11784
I have the 1258TG but am using a Brushless Hobbies ESC. No glitches, no noise. Works like a dream.
drtdvl4 is offline
  #11785
Acill's Avatar
All digital servos make the sound you hear. Its just the nature of them.
Acill is offline
Old 05-08-2012 | 12:34 PM
  #11786
Mizchief's Avatar
I have that setup. It's not glitching, it just the servo trying to adjust it's self. If there is any stress on the wheels when you turn it on you'll get that. Usually if you pick up the front end and set it back down or wiggle the wheel on the tx it stops.
All my savox's do this. I think th aluminum case causes the noise to be louder htan with a hi-tech or other plastic case brand.
Mizchief is offline
Old 05-08-2012 | 12:47 PM
  #11787
Lake Ober's Avatar
Ok, sounds like it being noisy is just the nature of digital servo's... especially when they are connected to a MMP. Thanks for all the input everyone!
Old 05-08-2012 | 01:09 PM
  #11788
elex300's Avatar
Yeah Lake, Dont sweat it. I run them on my Tekins and they are noisy as hell but its woth putting up with. They are awesome servos.
elex300 is offline
Old 05-08-2012 | 01:24 PM
  #11789
Yes, the Avid hex adapters that everyone is talking about on here will work great for you --> http://www.avidrc.com/product/5/acce...ccesories.html. [/URL]
It looks like I need a steering block and axel. Will I need new bearings too? Anything else??
Mark
mark in wi is offline
Old 05-08-2012 | 04:11 PM
  #11790
Yes Im saying no matter the ESC any digital servo will make that noise. Its nothing more than the servo finding center over and over again. Secondly yes even with an external BEC connected it will still make noise. Its nothing to worry about. Heres the deal with the castle MMPs. Some of them will run the savox stuff along with some of the other high draw servos on their BEC and some wont. They are renouned for having an extremely weak BEC. I have first hand experience with this as I have beta tested several componets for Castle and this was a known issue from day one with the MMP. Most can get away with a capacitor(spektrum or Novak) in the receiver port. Some cant depending on the unit(ESC). As some were better than others.
On another note I just ordered the Avid Spring sets for front and rear for my V2s with GHEA collars. I have been running the Losi springs which I didnt care for. The rates, especially the front were not close enough to the factory associated stuff. I also grabbed the carbon fiber rear hub towers which look better than the Associated set as they give more setup options. Was going to get the Avid 12mm clamping hexes but my Proline hexes seem to be doing just fine. I dont particular like the set screw on the Prolines but they are far better than the J Concepts clamping hexes which strip just looking at them.
Ill be posting some results once I run the Avid springs this weekend. Along with my impressions of the rear hub towers.
