SC10 Thread
Old 05-04-2010 | 12:25 PM
  #4261
cyclone x's Avatar
my truck is getting so lose in the rear would mounting some weight in the rear help or no
cyclone x is offline
Old 05-04-2010 | 12:55 PM
  #4262
Matt Trimmings's Avatar
What tires are you running, Tires are the most important part of a setup
Matt Trimmings is offline
Old 05-04-2010 | 12:56 PM
  #4263
mpluis's Avatar
Try this:http://www.amainhobbies.com/product_...-Carriers-Blue
mpluis is offline
Old 05-04-2010 | 12:58 PM
  #4264
cyclone x's Avatar
the box stock tires
Old 05-04-2010 | 09:47 PM
  #4265
$Tmoney$'s Avatar
Originally Posted by will g
anyone tried this yet
I run them and there AMAZING makes the factory team shocks feel like kyosho shocks
$Tmoney$ is offline
Old 05-04-2010 | 09:57 PM
  #4266
F N CUDA's Avatar
All agreed, get tires and don't forget to "sauce" the crap out of em (rear only) if you're still loose.
Then get a set of rear hubs that will toe in the rear end as suggested above.
You can get the aluminum ones or use Losi XXX T rear hubs and hinge pins (cheaper, just need to drill the arms to 1/8 inch).
They come in +1 and +2 degrees toe in.
Of course, use one of the setups from the fast guys on here and you'll be real close.
F N CUDA is offline
Old 05-05-2010 | 06:21 PM
  #4267
jdearhart's Avatar
Will, read this:
http://www.rcshortcourse.com/forum/s...ead.php?t=1382
jdearhart is offline
Old 05-05-2010 | 06:36 PM
  #4268
KevMc's Avatar
Originally Posted by jdearhart
Using that bit of tech on your SC10 build Jack?
KevMc is offline
Old 05-05-2010 | 09:59 PM
  #4269
the box stock tires
I would bet that is the majority of the problem right there. Most people use either JConcepts or ProLine Tires, find out what others are running at your track and get some. you will be amazed at what the correct tires will do.
Old 05-06-2010 | 10:23 AM
  #4270
jdearhart's Avatar
Maybe!
Old 05-06-2010 | 12:32 PM
  #4271
cyclone x's Avatar
ok im gunna try the jconcepts
thanks for the help
Old 05-06-2010 | 03:30 PM
  #4272
F N CUDA's Avatar
thanks for the help
Have you seen them go at your track?
If so, and they work, jump on em.
F N CUDA is offline
Old 05-06-2010 | 03:32 PM
  #4273
cyclone x's Avatar
yeah the guy has the goosebumps
Old 05-06-2010 | 03:48 PM
  #4274
F N CUDA's Avatar
Lots of great patterns to choose from, sure the Bumps are the best?
You might just drive around that guy with AKA Wishbones or JC Barcodes.
F N CUDA is offline
Old 05-06-2010 | 04:49 PM
  #4275
cyclone x's Avatar
ok well it never hurts to try
