SC10 Thread
Old 10-27-2010 | 10:58 PM
  #5011
T-BirdJunkie's Avatar
From: Norwood, OH...and CCRCR and The OhioRCFactory
So, ok.
Was running the stock 3? degree rear toe block with 1 degree STRC hub carriers and 0 camber. Truck drove great.
Swapped to 0 degree Trinity rear hub carriers, the 4 degree toe block, and set the truck back at 0 camber.
Now it's oversteering all over the place; nothing else has changed about the setup. Did the longer camber link do this somehow? It had to be turned out quite a bit to get it back to 0 toe since the Trinity hub carriers are not as tall as the STRC hub carriers.
PLEASE ADVISE, GENTLEMEN.
T-BirdJunkie is offline
Old 10-27-2010 | 11:03 PM
  #5012
racer1812's Avatar
Super Moderator
Originally Posted by T-BirdJunkie
So, ok.
would think the longer camber link would add traction, going to 4 deg. block shortens the WB but neither of these should make a HUGE difference....got me man
racer1812 is offline
Old 10-27-2010 | 11:13 PM
  #5013
That's what ThunderbirdJunkie thought, too.
Got another race day on Friday, so gonna dial in about a half degree of neg in the rear and see what happens. Should be colder though. probably gonna put 25 or 20wt oil in the shocks since they've all got 35 in 'em now to compensate for the temperatures dropping.
Old 10-27-2010 | 11:40 PM
  #5014
racer1812's Avatar
Super Moderator
I don't really run in varying temps much so I'm not sure but in the "old days" before silicone oils we would have issues with shock oils getting thick, and I mean REALLY thick in the winter (back of the truck on the way to the indoor track) I always thought silicone oils were not affected by temp changes? Like I said it's never been an issue lately running indoor and I'm nicer to my rides now, they get to ride in the back seat of my truck with the heat on..:lol
Old 10-28-2010 | 12:52 AM
  #5015
Eh, it's gotten noticeably worse. The bumpy sections of the track ThunderbirdJunkie's truck floated over a month ago are now tossing the truck all over the place at 10pm during the main when it's like 35 or 40 out, as opposed to 60-70. it'll be closer to 30 out this Friday rather than the 65 (unseasonably warm) it was tonight, so it's going to be a huuuuuuuuge difference.
The silicone fluids aren't affected AS much, but they definitely aren't perfect.
Old 10-28-2010 | 01:00 AM
  #5016
kneedeeppow's Avatar
could anyone give me a good spur/pinion ration for a 10.5t.am running 18t pinion 87t spur.of the mark the truck is very tail happy.have played with the throttle curve on esc and transmitter and its still pretty twitchy.
kneedeeppow is offline
Old 10-28-2010 | 01:11 AM
  #5017
10.5 and lower is a big motor for the SC10. Even the 3200kv crapper that's in the truck right now the truck will burn the tires all the way down the main straight.
Have you considered laying off the throttle?
Old 10-28-2010 | 01:17 AM
  #5018
10.5 is our legal limit for racing. i gotta shave some of the lead of my trigger finger
Old 10-28-2010 | 06:06 PM
  #5019
bjholz's Avatar
What rear hub are you guys using? I was thinking getting a .5 degree aluminum hub
bjholz is offline
Old 10-28-2010 | 07:22 PM
  #5020
mjk1210's Avatar
Way undergeared, no? I run 21/84. It makes launches a bit smoother. Also try heavier oil/springs all around. Too much body roll is hard to drive.
Since I stiffened it up my 7.5 wont even make it fishtail.
mjk1210 is offline
Old 10-28-2010 | 07:27 PM
  #5021
mjk1210's Avatar
you really need to try em and see what you think. But a cheaper/easier to test alternative is the pack of rear toe blocks with antisquat shims. 2.5 to 4 deg with a.s. shims all under $10. Scotty should have the pack.
mjk1210 is offline
Old 10-30-2010 | 01:50 PM
  #5022
WillD's Avatar
Just for my own reference, what is the original kit (not rtr) rear toe-in? 2 or 3 degrees?
Also what do the newer brushless RTR's come stock with now?
WillD is offline
Old 10-30-2010 | 02:13 PM
  #5023
trx450racer174's Avatar
Original toe block i thought was 2 deg.
trx450racer174 is offline
Old 10-30-2010 | 03:08 PM
  #5024
Cameron Kellogg's Avatar
No it was 3 on all the models.
Cameron Kellogg is offline
Old 10-30-2010 | 03:52 PM
  #5025
WillD's Avatar
I was thinking 2 as well. I thought one of the added tweaks of the RTR was another degree of toe-in?
WillD is offline
