SC10 Thread
Old 10-21-2010 | 09:13 AM
  #4996
racer1812's Avatar
Super Moderator
Originally Posted by ShortCourseOnly
On bumpy tracks I run Blue/Silver 35wt front and green 30wt rear. Great forward traction and soaks up the bumps pretty good. If the track is smoother I increase front spring rates and go 40wt front/35wt rear. I always keep the 5wt difference between front and rear for forward traction.
I run the same set-up, tends to have a little more body roll than I would like (can get a little tipsy on the high speed stuff) but it "floats" on the bumps and has tons of forward bite. Everything else is built to the manual other than the above settings..
racer1812 is offline
Old 10-21-2010 | 07:05 PM
  #4997
Ok.
HeavyD99 is offline
Old 10-21-2010 | 10:12 PM
  #4998
so one was an x-11 run 4 times in a sedan, doesn't mean it wasn't damaged before you got it....what did you gear this motor? what were the other 3 motors and their gearing? i know i gear the x-12 about 3 teeth lower than the x-11.
truck driver is offline
Old 10-21-2010 | 11:51 PM
  #4999
T-BirdJunkie's Avatar
From: Norwood, OH...and CCRCR and The OhioRCFactory
Originally Posted by HeavyD99
Ok, I've officially got a problem. I've burned up 4 13.5's in about a year in my SC10 - ya, 4. I bought all of them used, but they were far from used up - one was an LRP X11, and it was ran 4 times, in a sedan - and lasted one night of racing indoor offroad. The others were nearly as new, and they all gave up on me eventually within a mont hor two - and I only race every other week. I'm running the same gearing as everyone else - 75/25 - and then I geared down to 87/23 - still killed a motor. I'm running an LRP Sphere TC, on default settings. I do not go full throttle around the track for the 6 minutes of racing, but it's an SC - it's heavy and hard on stuff, but no one else is having these problems. I've switched ESC's, motors, gearing, tires, sensor wires and ESC settings. Nothing has helped. I run the gear diff for now and an Aoxing 5000mah 20C pack. The drive train is free, no binding.
Any ideas?
Try buying a new one and see how long it lasts.
T-BirdJunkie is offline
Old 10-22-2010 | 12:33 AM
  #5000
Old 10-22-2010 | 01:00 AM
  #5001
nice work on the turnbuckle... the hinge pins bend quite often, but that turnbuckle is excellent. he should send you a new one!
Originally Posted by T-BirdJunkie
SmItH_aLeX is offline
Old 10-22-2010 | 08:38 AM
  #5002
Lunsford hinge pins bend often?
Hmm.
Might just put the steel ones back in there then
Old 10-22-2010 | 09:02 AM
  #5003
Ae*Driver*70's Avatar
Arrow AE Is Killer Of All......
RACE BREED KITS ARE NOT FOR NEWBIES OR THEY ARE NOT FOR BASHERS !
Ae*Driver*70 is offline
Old 10-22-2010 | 09:14 AM
  #5004
1Fastpede's Avatar
T-bird.. lets hear the story on how you did that lol. ill take a guess. high speed full throttle turn and wall ?
1Fastpede is offline
Old 10-22-2010 | 11:45 AM
  #5005
Whatever you say, good sir
Nah...after the race Weds night we had some gnarly winds picking up going toward that decent-sized double right before the small double
After a couple post-race laps of the wind pulling the nose of the truck up in the air, ThunderbirdJunkie thought "hmmmm..." and approached said double with some decent speed and let off the throttle. Wind gusted, pulled the front end up, stabbed the throttle hard, and completed a great backflip with the truck
Tried it a couple more times, and it didn't work out so hot.
Old 10-22-2010 | 12:10 PM
  #5006
anyone looking for a used FT SC10 (conversions) in roller and semi roller form let me know. i got a few to get rid of. $100 roller (shocks are RTR) or $80 without shocks.
Pimpin is offline
Old 10-22-2010 | 01:31 PM
  #5007
Whoops wrong thread
Old 10-22-2010 | 04:28 PM
  #5008
offtraxx's Avatar
conversion? I was at the hobby shop with my t4 in hand today. new parts (chassi, wheels, body, body mts, frt tower, and couple other things) came to $165. left the t4 behind with $150 and have a highly upgraded ft sc10 setup by the store owner
just proves u can actualy get a roller for less than converting
offtraxx is offline
Old 10-22-2010 | 06:48 PM
  #5009
PIIHB!'s Avatar
Damn T-bird. I beat the heck outta mine tonight at the track
PIIHB! is offline
Old 10-22-2010 | 10:23 PM
  #5010
Ditto
