Like Tree22Likes
Old 10-07-2010, 07:24 PM
  #2281
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
Originally Posted by grapejuice
I really like it!! Came at the right time too since it was time to replace the rear bumper anyway. Rearend feels really planted(little more then before with just the side weights), I also went up in shock wt. 2.5 in the rear as well....now I think I am done with the set-up...
Now I think it's time for you to post this awesome setup..... by any chance are you running 37.5 in the rear???? Thanks
Bman's 3XNT is offline
Old 10-07-2010, 07:52 PM
  #2282
Matt Howard's Avatar
Originally Posted by Dlewis4
Awesome. Now get some fatboy shirts/jackets. I would be all over em if they were 3 and 4x.
I noticed some of the clothing is labeled as "skinny fit" I think most racers would need the opposite of that
Matt Howard is offline
Old 10-07-2010, 07:54 PM
  #2283
Ryan Lutz signed with Team Durango! Look Out........
Old 10-07-2010, 08:00 PM
  #2284
I just noticed that over in the nitro section, only good things can come of this
Old 10-07-2010, 08:18 PM
  #2285
DRCRacer299's Avatar
I'm very excited to begin running the entire Durango lineup!
Thanks guys! Hopefully will be able to be of assistance in the near future!
DRCRacer299 is offline
Old 10-07-2010, 08:20 PM
  #2286
awsome news for both Durango and yourself, good luck at the worlds
Old 10-07-2010, 08:28 PM
  #2287
R-E-A-P-E-R-'s Avatar
Very cool indeed
R-E-A-P-E-R- is offline
Old 10-07-2010, 08:29 PM
  #2288
drs92's Avatar
Trader Rating: 45 (100%+)
Thats awsome fav. driver right there Durango looks killer
drs92 is offline
Old 10-07-2010, 08:43 PM
  #2289
Dlewis4's Avatar
Trader Rating: 148 (100%+)
WOOT! Now we can get some factory support! Lol.
Congrats on the new deal Ryan!
Dlewis4 is offline
Old 10-07-2010, 09:37 PM
  #2290
Konich's Avatar
Well I pretty much had about 1/2 of my bearings blow out on Wednesday night. If you have the kit bearings I would take a really good look to make sure they are in good shape. Mine apparently gave out without warning. First it was the hub, then the front diff.
Luckily I have a set of blue-sealed spares and I'm going to go through the whole car and start swaping them out. With the number of runs I have I suppose its about time anyway.
Watch out Grape! I mounted my new Azarshi body and undertray along with the rear skidplate weight Now to bump up my rear shock fluid 2.5
Konich is offline
Old 10-07-2010, 10:02 PM
  #2291
dangerwr's Avatar
Do the whole car with Boca Greens. They fit perfectly and doubt you will ever have to look back this season . ..
dangerwr is offline
Old 10-07-2010, 10:10 PM
  #2292
Konich's Avatar
The good thing is I can actually take apart my car. Hell I didn't even need a hand from the wife to slide that front diff out. Now that the fall season is here its time to get SERIOUS!
Konich is offline
Old 10-08-2010, 04:59 AM
  #2293
Congrats man! Good luck with the new venture.
Old 10-08-2010, 08:21 AM
  #2294
grapejuice's Avatar
Trader Rating: 151 (100%+)
Here is my current set-up, DEX410R. Track I run on is indoor 80'x40', clay mix, high bite, Losi Pink tires or Jconcepts Gold tires:
Front End-
Camber link: #2 on tower(middle inside), "R" caster hubs
Shocks: Black springs, 2 hole x (55) drilled piston, Losi 35 wt.
Middle on tower(carbon tower), outside on arm
Diff: Losi 15K
Toe: 0 deg.
Camber: -1 deg.
Ride height: 18mm
Front ackerman
Rear End-
Camber link: #3 on tower(second from the bottom inside), #2 on hub(middle)
Shocks: Light Green springs, 3 hole x (55) drilled piston, Losi 30 wt.
Middle on tower(carbon tower), middle on arm
Diff: Losi 5K
Toe: 0 deg, hubs
Camber: -1 deg.
Ride hight: 19mm
Anti-squat: RF -2, RR 4
Side and Skidplate weights
LRP SXX TC Spec w/ X-12 7.5 (prototype rotor), 87/21 gearing
grapejuice is offline
  #2295
rfleck's Avatar
Trader Rating: 58 (100%+)
[QUOTE=Konich;8042072]Well I pretty much had about 1/2 of my bearings blow out on Wednesday night. If you have the kit bearings I would take a really good look to make sure they are in good shape. Mine apparently gave out without warning. First it was the hub, then the front diff.
QUOTE]
The stock bearings aren't all that great IMO. Mine were really "raspy" after just a couple of weekends running on a hard packed surface which doesn't get the car dirty at all.
rfleck is offline
