Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread
#782
is that extra part the nimh/nicad battery holder?
#783
That part is for the front of the battery strap.
(edit: Oops, it's not used on the 410R. Packaging error?)
And, it looks like your diffs are upside-down. Screw heads should be on bottom.
#788
Ok , just started building my DEX410R and it is my first ever 1:10 buggy.
I have bought some DEX410 metal option parts as upgrades and replaced part no 330126 front arm hinge pin retainer with the metal option.
again I have done the same with the front of it and the hinge pins do not fit snug into the eyes, whereas if I used the plastic original parts the hinge pins fit exactly in.
Do i need to replace the hinge pins?
#792
That is really a beautiful 1/10 buggy. If I were to run 1/10 buggy, I would have to go with the DEX410.
#794
Should have my 410r here Friday what gearing would you say I start with running a tekin 5.5 and is there any must have upgrades I should ad as soon as I can from the pro version thanks for the help
#795
Check out the review: http://www.oople.com/rc/photos/review410r/index.html
My first upgrade will be the alloy front suspension block(s), then the rear gearbox supports when the composite ones break.
