Tekin RX8 1/8 Scale Brushless ESC Thread
Fan Removal
The fans are removed because they don't last very long. If they break in the middle of a race you will thermal because the fan blocks the air from reaching the aluminum. If you remove it on a Short Course 4x4 you will run well with in temp range, so why risk it?
The other thing I do is an in-case switch delete. Keep it simple and keep the car reliable.
I haven't run a fan on any of my cars for a long time. I have a couple in my pit box so that if I hit up a loamy/amp hungry track when its approaching 100 degrees out I'll throw one in if I ever hit 7 leds.
http://manicrcfans.com/index_files/Page474.htm
Also as casper says, drop down one pinion tooth, that should bring down temps and give you a little more bottom end at the cost of top end.
Could someone tell me if the T8 2650 buggy motor can be used with the MMM esc?
Yes.
Brownout: Savox, Spektrum or Tekin?
Hey Folks,
I have a problem with my Spektrum SR3001 Pro receiver shutting off (rebooting I guess). It happens very quickly and easily, I literally turn the wheels from left lock to right lock and back left in under a second and it shuts off. Keep in mind the car is sitting still, and even have the wheels off the ground. Using Turnigy 5600 50C-100C hard case lipo's that are fully charged. I am using a Savox 1257TG servo, and the RX8.
I have an 8700uF capacitor on order to try to fix the problem, but it is my belief that just turning the wheels a couple of times shouldn't be enough to cause a brownout.
So, here's my question:
How do I determine if its the receiver, ESC or the Servo?
If I measure the voltage on the receiver, and see that its dipping below shutoff voltage (4.8 volts I think), is it because the servo is pulling to many amps, or the ESC is not providing enough? Or should I just put in the capacitor and not worry about it?
Hey Folks,
Listen to the sevo and if it is buzzing loudly, take out some end point adjustment.
Hey Folks,
Spektrum part # SPM1600
The servos are known to be power hungry. What you must understand is that the BEC has to power the receiver, servo, personal transponder, external fan if equipped, and sensor system. The servo shouldn't be pulling that many amps anyhow.
A voltmeter may not catch this quick of a voltage drop. The cap should correct the issue mind you. You don't even need one that large. A 1000uf 16v cap would do it, readily available at a Radio Shack,etc.
Yes, adjusting the endpoints was my first thought, no binding. I even dialed down my steering rate to 50% and it still happens. I do notice that the servo buzzes even with the wheels straight most of the time, but it will go away if I tweak the direction a bit. Would this point to a possible servo issue?
A 16v 1000uf cap should be small enough to stick next to the receiver without issue. The shorter the leads, the better.
instead of a cap you could use an external BEC. but I doubt it would save you any space. another option is you could get a high voltage servo and wire it to one of your batteries directly, no BEC or Cap needed.
Servos are always looking to be "centered." However digital servos are much more accurate so they're often "busier" than an analog servo.
