Tekin RX8 1/8 Scale Brushless ESC Thread
#271
It hurt believe me. Hopefully saves us from hundreds of where are they emails since we really have a lot of other things to do.
On the bright side we did get some preproduction motors with the anodizing and the etching and they look sweet! Everything really is running perfect and now we just have to build a lot of them.
#272
That's great news! Aside from the motor images posted on the Tekin site would we be able to get a sneak preview of the recent preproduction units?
#273
#274
I got a question about solder tabs. Never used them before so... It takes alot of heat to solder 10/12 guage wire. Whats the biggest the esc accepts? Looks like the slots is were the wire goes. Is there any worry and what stops the heat while soldering from unsoldering the wire terminal from the inside of the esc board and same thing on the motor. Whats stops the heat while soldering from unsoldering the other side of the solder tab on the inside of the motor?
Are these going to be as effecient as the Neu motors?
What are you guys setting or what is the max temp limit for the motors/magnets?
I see all the stuff on stormer. Is anyone backordering one?
#275
I got a question about solder tabs. Never used them before so... It takes alot of heat to solder 10/12 guage wire. Whats the biggest the esc accepts? Looks like the slots is were the wire goes. Is there any worry and what stops the heat from unsoldering the wire terminal from the inside of the esc board and same thing on the motor. Whats stops the heat from unsoldering the other side of the solder tab on the inside of the motor?
#277
Originally Posted by RCBLUE
Poor connections however cause higher resistance and resistance and current cause heat. Excess heat unsolders wires. Plain and simple, make a good solder joint and forget about it, because it will not cause any problems.
#279
It takes a lot of heat, if you did flow the solder on the posts down on the board and it became loose, you were on it WAY too long. A good solder joint takes less than 5 seconds to flow if you're doing it right. Sometimes even quicker. It's all about having both parts you are joining tinned and heated when you bring them together and then they will flow together very nicely.
#280
The guys are right. We use High Temp solder on the motor/battery connections on the esc/motor to prevent this from happening in the first place. You will be fine soldering the 10 awg wire to the motor and esc.
#282
I have mine backordered with the 1700 KV truggy motor and I am planning on running 5S. I was gonna run 6S but I was told that would be overkill, so I will try the 5S and see how it performs. I ran the Novak with the 3400 KV on the 3S last year but IMO it got rather warm, so I decided last year that I would wait until Tekin came out with an 1/8th scale system to buy a new one. I love my RS Pro and can't wait to get the RX8.
#284
Max temps on the motors, I keep them under 180*. Just like the 1/10th scale motors, run them up too hot and you risk cooking the windings, the magnets starts to de-magnetize and things go bad.
#285
Ty's right, 180 is where I'd start to look at my setup to change.
The esc has theral protection and should not be a problem. We've been testing them without the fans and have yet to thermal one.
