JConcepts Thread
For Smoothie 3's when would I use G1,2,or3? Currently I am using Blue 3's on my 4wd at my local track that is humid and has a ton of grip. These tires are great!
However In CNY/WNY the temps will drop, a lot of the times below 30 degrees, which you will need to use a very soft tire. I think Green would be my choice, but just want to make sure I understand the other compounds.
G1 = Hard
G2 = Med
G3 = soft
Compound guide
Not sure who to really ask on this, but after trying out the inner sidewall supports on both 1/8 turf tires and 1/10 Stadium truck carpet swagger fronts, be cool to have some created that fit the 1/10 buggy carpet sized tires, Find it more consistent to put these in versus the sidewall gluing. With stadium truck carpet tires versus sidewall glued set, I only need to drop my dual rate 5% over what I normally run was excellent.
`1/8 E Buggy on our outdoor turf was so much better as well with them installed front and rear due to the resistance to tire fold over front and rear in the swagger and nessis I was using.
For other folks that run smoothie 2 w/ silver compound on indoor clay - what are some of your favorite tire sauces? Do you find yourself having a few on hand as the track changes? I seem to find that after a rebuild the track is much less consistent and changes throughout the day more, and after its been that way for a month or two its more overall consistent and I find myself switching sauces less.
Been trying sticky kicks lately (silver, blue and yellow), and previously liked grip doctor. But curious if some are better than others for smoothie's. Thanks!
Has anyone ran the new Arina buggy tires yet? How do they compare to a Kosmos, Recon, and Reflex?
I assume they are meant for tracks with plenty of loose dirt but maybe they work on dry dusty tracks that are hard packed as well……
The other more rough and can take longer for a line to form but still be loose.
Personally I thought as long as thre was some moisture to the track and the surface wasn't too hard, they worked pretty well, pin height from what I can tell seemed to work better when there wasnt' alot of loose dirt / dust, where in those conditions I'd use more like a falcon or dirtbite instead.
Once things harden up though you can slick the tires pretty quick in the green compound even if cool outside.
Any plans to offer the Smoothie 2 LP truck tires in Gold compound? The silvers work great on our clay track, but generate a little too much grip and only last a few races. A harder clay compound would be perfect.
494Likes
