Like Tree494Likes
JConcepts Thread
Old 04-15-2025 | 06:31 PM
  #10696
RossKo's Avatar
Any update on when the 2.2 truck goosebumps will be back in stock? They have been out of stock for a couple months now.
These are about the only loose dirt truck tires on the market. I wish there was a little more selection for stadium truck on outdoor tracks.
AHR43 likes this.
RossKo is offline
Old 04-16-2025 | 05:03 AM
  #10697
Cain's Avatar
Tech Legend
Be cool if those sirens asnd drop steps could be offered in a dirt compound.
BRabbit likes this.
Cain is offline
Old 04-16-2025 | 06:24 AM
  #10698
AHR43's Avatar
Jcons has the lockness and siren tires that would be a good starting point for rear tires. They don’t really have much for front 2wd spike tires. You might want to run rib tires OR look at Schumacher since they have a big line of grass/astro tires such as the mini spike, full spike and stud
Thanks for the reply and recommendations, RossKo. Wish listed a pair of Siren. Amain doesn't list the lockness. Went to the JC website and found them. They look even better for my application. Both are under consideration for now. Looking like my sprinter will have to accept a low profile tire as that seems the trend now.
Ribs up front give me a push on my track. Found that true with both 2.2 Buggy/ST and 2.2/3.0 SCT ribs. So pins, blocks or spikes up front are the go-to. Perhaps when JC weighs in they'll have a buggy front recommendation. Much prefer the narrower 2wd buggy front over the wider 4WD front.
Cheers. -AC
AHR43 is offline
Old 04-16-2025 | 06:41 AM
  #10699
Cain's Avatar
Tech Legend
Cheers. -AC
Buggy-sized maybe look into a Siren front and rear. The 4wd front sirens may be a hair chubby but may be what you want on 2wd standard front wheels. Drop steps on rear could also be a great option.
AHR43 likes this.
Cain is offline
Old 04-16-2025 | 06:55 AM
  #10700
PW's Avatar
PW
Cheers. -AC
Unfortunately I don't have any experience running on natural grass, but I would think the Drop Step or Siren to be a good choice in the rear. As mentioned, we don't have a full pin style slim 2wd front, so you would could go with a Swagger or Swaggoo. Or you could get a little more aggressive and use a standard width 2wd front wheel with the Siren 4wd front tire, which fits nicely
AHR43 likes this.
PW is offline
Old 04-16-2025 | 07:03 AM
  #10701
PW's Avatar
PW
Unfortunately not sure of ETA on the Goose Bumps, but I do see they have them on order.
There was a little easter egg in this RC10T body release that might be something to watch for
Cain, nitrous36, AHR43 and 3 others like this.
PW is offline
Old 04-18-2025 | 06:40 AM
  #10702
AHR43's Avatar
Thanks, guys and of course Paul for the recommendations. Have a pair of 2.2 Drop Step on order for the rears and Dirt Tech front inserts for the fronts. Went with a competitor's pair of tires for the front. Only because my sprinter build will class as a 2.2 'midget' on my grass track and want narrow section fronts to maintain a realistic look. Cheers and best regards. -AC
[ Edit: And, oh yeah also on order is a JC 17T brush motor. This is a brush motor build with an ages old 19T Reedy in it now. Figure the newer 17T will add a bit to its performance.]
Cain likes this.
AHR43 is offline
Old 04-19-2025 | 09:29 PM
  #10703
MokuMekaPilot's Avatar
If those wheels come out for the T6.4 I will lose my mind. They look so damn cool.
Cain likes this.
MokuMekaPilot is offline
Old 05-25-2025 | 01:50 PM
  #10704
Tiggertrucks's Avatar
Does anyone know if the tire balancer will work with T6.4 offset wheels?
Tiggertrucks is offline
Old 07-01-2025 | 08:54 AM
  #10705
Cain's Avatar
Tech Legend
Few questions on some 1/8 tires:
- When do you find you go with Relapse versus Rehab
- How often do you find that id you end the day on A2 Compound, that you start on Green or is it Blue more common
- When will the Kosmos for 1/8 be up ro actually order?
Cain is offline
Old 07-01-2025 | 01:20 PM
  #10706
PW's Avatar
PW
- Relapse seem to have a little more on-power traction when the track is slightly dusty and the Rehab seems to hold the corner a little better for more cornerspeed.
- That all depends on track conditions; is it cooler in the mornings, did they water at night or in the morning, etc...
- I'm assuming you are referring to the truggy Kosmos? They are in route and should be available soon. Buggy Kosmos are currently available.
Cain likes this.
PW is offline
Old 07-04-2025 | 05:16 AM
  #10707
AHR43's Avatar
Quick comment here for the JConcepts website Blog. Esp. the weekly Race Team Update. My go-to for oval track results around the country. Like the listing of JC products used too,
Keep on keepin on. Happy 4th. -AC
PW likes this.
AHR43 is offline
Old 07-15-2025 | 10:31 AM
  #10708
Default B84
How are those B84 bodies coming along? F2 & P2 first? S2 & S15 too!?
(I know the B74 bodies fit ok but I’m looking for a tighter fit as I run in dusty conditions some days).
HeavyD99 is offline
Old 07-15-2025 | 10:35 AM
  #10709
PW's Avatar
PW
They are in the works and should be ready the end of this month
HeavyD99 likes this.
PW is offline
Old 07-15-2025 | 10:58 AM
  #10710
Any chance of a P2 coming for the TLR 22x 2wd?
Cinnabun is offline
