Team Associated B7 and B7D
#1081
I run the thrust washer assembly for a bit on by putting an old screw through the thrust and an old outdrive and running the thrust bearing in using a drill at slow speed. I then flush all the grease out and clean everything then re-grease and build the diff.
When I build up the diff I initially set it so that it is just a slight fraction tighter than what would allow it to slip when turned with a light grip between finger and thumb whilst holding the outdrives on screwdrivers through the slots.
I run that diff in built into the car, hold one wheel and run 30% throttle for 2 minutes then swap to the other side.
Back the diff off all the way then reset it by holding the screw and turning the wheel to find the desired tightness.~
If have found that the debris from running in a caged thrust bearing very quickly kills it under power in the car, even more so if the main ball diff is run in whilst in anyway tight.
The old school method of tighten it hard down and back off 1/2 turn doesn't work with these caged thrust bearings.
As has been said use the old 12mm lower spring platforms. You can stretch the springs over the ledge on the 13mm upper spring platforms (I recommend a small dot of CA glue to stop it popping off in use), flip them over (spring can drag on the threads though) or use the Schumacher upper spring platforms (same thread) as they have no ledge and a longer sleeve to guide the spring. I mainly use the first method myself.
#1082
I was hoping to be talking about setup for dry astro today but sadly the track never dried yesterday :'(
Did give me chance to try a few more things on the wet setup and there will be an new one posted on CML very soon, found another 3 10th so back-back it is now nearly 1s/lap quicker than the B6.4 on the exact same tyres, wow.
#1083
Weather is looking rubbish all through next week too - 4WD regional next weekend and current (all be it too far out) forecast is WET
#1084
Can u please explain me how the flap with the 1.1mm hole in the front Piston works? How it is Made?
And is the Setup Sheet on CML b7d the latest one? For Carpet.
#1085
I cant see the servo weight on tmg where did you get it?
are these the blanks you talked about for the hinge pins?
https://www.ebay.co.uk/itm/222892624...mis&media=COPY
Are there any positions the short ones would be a problem or longer ones for that matter?
A guy I was racing against last sunday had his gearbox implode on braking from high speed destroyed all the gears. Seem to be quite a few issues with the car
#1086
We obviously don’t know much. But anecdotally it sounds like the kit bearings may be a problem. I could only think a bearing failure would cause the transmission to implode. I highly doubt the idler gears are the cause since the kit ones are unchanged from the B6. Poor bearings could also explain the overheating.
#1089
Built my kit and after i noticed that the inside of the front wheels rub on the a-arm and ball cup. I checked everything multiple times and had others look also and found nothing wrong with the setup. We compared it to another b7 (carpet) and found that my dirt has 5.0 axles and the carpet has 6.5 which dont rub. Anyone else experiencing this issue with the wheel rubbing? (I have tried different manufacturer wheels also)
#1090
#1091
#1092
shortcut3d
The ball bearings that was provided by the company, is of ABEC-3 grade.
By the way, I threw away a few equipped 5x10x4mm ball bearings, which was used for idler gears., the quality of the ball bearings is not good.
Therefore I have ordered the ABEC-9 grade ball bearings, will use it on idler gears and top shaft
#1094
i encountered ESC cut-off.
Here's what happened.
Installed Hobbywing G4 17.5T motor, with 30T pinion gear & 72T spur gear
SkyRC Toro 160A Pro ESC used, PWM set to 4K, all other setting remail default value.
Ran just 3 to 4 laps, esc cut off power to motor, due to motor overheat
