Tekno RC ET410 Thread >
Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Like Tree469Likes
Last edit by:
Print Wikipost
Old 07-27-2018 | 06:59 AM
  #181
Originally Posted by AJH387
So which of these would you guys go with and why? I know Matt gave his input on what those guys were running. I just can't decide so I was wanting to see what you guys were going to use and why. Thanks.
https://www.amainhobbies.com/hobbywi...020230/p742128
https://www.amainhobbies.com/hobbywi...020421/p604317
https://www.amainhobbies.com/tekin-r...tt2753/p464776
If I can get the SCT Pro ESC to fit, then I'll definitely go with a 4 pole SCT motor... only problem is that this might be too much power, I had tested this motor in a Hyper10TT on our turf track and it would tend to do wheelies if you punched the throttle too hard:
https://www.ebay.com/itm/GoolRC-550-.../142783448794?
AJH387 likes this.
billdelong is offline
Old 07-27-2018 | 07:36 AM
  #182
rayzcar's Avatar
So who’s gonna be the nice person with too much time on their hands to make a list with part numbers of what parts are different between the EB and ET? Essentially, if I wanted to convert my spare EB410 to an ET410, what do I need to get and how much is it going to cost me? At least can do that comparison first before likely deciding to opt for the full kit. Thanks in advance.
rayzcar is offline
Old 07-27-2018 | 07:53 AM
  #183
AJH387's Avatar
Ya that is the balance I am trying to find. It's a truggy so I think it should have big power etc. But I don't want it to be completely not usable. The 2-pole 5.5 seems good but I just don't know if I want something with more punch w/o going over the line.
AJH387 is offline
Old 07-27-2018 | 08:31 AM
  #184
For you guys all discussing what power plant to run, I would take note of the following statement from Matt W.
Matt - Probably would recommend a 10.5 for something similar to 13.5 in a buggy. I personally run a 6.5 in it and it’s pretty fast. Pro4 4600 will run in it but it has a lot of power and will need to be turned down in the esc.
So my suggestion is treat it like a 4wd buggy for Mod and start with your normal 6.5 / 5.5 and see how it feels. For Stock guys, 10.5 motors. I personally won't have a truck for a few months, but my intention is to try the 13.5 that's currently in my buggy and just swap it over and see how it feels. I'll also try a 10.5 if I have one laying around still. I plan on running a 6.5 in it though because I doubt that we'll have enough initially to split the class into stock and mod.
Which brings me to another point. Since this class is new, I suggest that you get together with people from your track and discuss if you guys are going to run spec, mod, or just open. At least for the first month or two until you can get more people driving them.
AJH387 likes this.
Bob Barry is offline
Old 07-27-2018 | 09:30 AM
  #185
EbbTide's Avatar
Pre order is up that was quick
EbbTide is offline
Old 07-27-2018 | 09:48 AM
  #186
AJH387's Avatar
Just ordered mine
AJH387 is offline
Old 07-27-2018 | 09:57 AM
  #187
Matthew_Armeni's Avatar
I don't think the XR8 will fit easily, at least if you want to also fit the rx on the chassis. So I'd go with the other two.
AJH387 likes this.
Matthew_Armeni is offline
Old 07-27-2018 | 10:06 AM
  #188
Hey Matt,
I see the recommended SCT wheels for the ET410 are for the Traxxas Slash offset... long story short, I'm currently boycotting Traxxas and would also like to re-use the same wheels that I already have mounted for my SCT410 if possible... are there any plans to make a hex adapter (possibly new axle?) to support zero offset SCT wheels?
Normally I'd run ST wheels, I'm currently running an XT2'17 with T4 wheels anyway, but ProLine doesn't currently sell Pin Points (or Pyramids) for ST and PinPoints are doing extremely well for my SCT with average wear of about 1 year of racing before the tires wear at the turf track in my area. In contrast I only get about 6-8 race days on a set of Prisms for ST.
If I do go with Slash compatible wheels, they will definitely be sourced from an aftermarket company, but it would be nice to share the same wheels with my SCT410 to help save space in my pit box
No plans for hex adapters to fit zero offset wheels. They'll fit, but be way narrow. you'd need an adapter that's about 12mm wider than stock.
Not sure why your tire wear is so drastically different between those treads. Is your SC 2wd or 4wd? You could also try JC tires.
Old 07-27-2018 | 10:08 AM
  #189
Originally Posted by boudin4evr
Im interested in trying the Tekno revised shock cartridge pieces to see if they work like the MIP cartridge kit
Pretty similar, we've had good success with the new guides.
Old 07-27-2018 | 10:13 AM
  #190
https://wwwcdn.teknorc.com/wp-conten...410_ET410.jpeg
rayzcar likes this.
Old 07-27-2018 | 12:42 PM
  #191
what was the reasoning behind doing a 1/10th Truggy instead of a 1/10 short course? There has never been this class why now? And to top it off, that is the most hideous body I have ever seen. Looks like a friggin tadpole
Bubonic-X is offline
Old 07-27-2018 | 12:52 PM
  #192
Truggy is more fun and this shares more parts with the EB410 than a SC would.
Everyone has an opinion on every RC body that's out there, we can't please everyone so we go with what we like. Won't be too hard to fit some other style body on the truck if you want to do that.
Old 07-27-2018 | 01:56 PM
  #193
Goof's Avatar
just not many races left around here to justify buying and i dont want to stare at it tell next yr but my 6yr old will love his birthday gift in March
Cant wait cant wait this thing is a beast
Goof is offline
Old 07-27-2018 | 05:40 PM
  #194
Thanks for info, didn't realize the Slash offset was THAT far out, I'll suck it up and look for some JC wheels with the Slash offset.
I'm comparing tire wear between 2WD ST (7.5T motor) with ProLine Prism Z3 against 4WD SCT (550-4300KV) with ProLine PinPoint Z3
Something about 2WD tends to cause the rear wheels to wear faster on turf, folks are reporting faster tire wear on 2WD Buggy vs 4WD Buggy too... used to be 2WD buggy was the most popular class but now 13.5T Wheeler is the main event every week. Presumably because 4WD tires wear longer at our club.
Nobody has any definitive reason why, but some folks are thinking that 4WD is more efficient with less tire scrub.
The biggest factor in longevity between Prism and PinPoint is the pin length... the Prism is very small, and once the pins start to round off, then traction dies off pretty quick... Pin Point is a really long narrow pin which can dig in deep into the turf... with a fresh set of pins, the car tends to be VERY twitchy where you need to dial back the D/R, then over time as the pins start to wear, then you can add some D/R to where the pins eventually wear down to the size of rounded Prism pins and that takes roughly a year of racing to get there
As far as JC tire compounds go, they don't make anything nearly as hard as the Z3 that ProLine sells... on turf, you want the hardest compound possible so the pins don't fold over, harder compound gives better traction and longer wear life
Only drawback to Z3 is that they are such a hard compound that they can be VERY difficult to glue, sometimes I will run a path of glue around the wheel bead first, then quickly snap the tire onto the bead before the glue sets up, ha!
Old 07-27-2018 | 08:33 PM
  #195
rayzcar's Avatar
Thanks for putting the conversion list together Matt. Looks like the cost per Tekno’s website will exceed the cost of the whole kit by about $56. Unless there’s going to be a conversion kit with a deep discount, makes that decision easy.
rayzcar is offline
