Tekno RC ET410 Thread >
Like Tree352Likes
    Hide Wikipost
Old 06-03-2019, 08:41 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Tekno RC ET410 Thread
Last edit by: rustyus
Welcome to the ET410 Wiki page.
  • 95% parts compatibility with the EB410 4WD 1/10th scale buggy.
  • Updated 3mm 7075 CNC chassis and revised A and B hinge pin braces.
  • 13mm hard anodized threaded shocks with locking spring perches.
  • New 32 pitch spur gear for ultimate durability
  • 3.5mm shock shafts with revised dual guide x-ring cartridge.
  • 7075 CNC machined adjustable hinge pin brace system.
  • Three high volume fluid-filled adjustable differentials.
  • Lightweight 7075 tapered center driveshafts.
  • Quick access to differentials and maintenance friendly layout.
  • Captured CVA front and rear driveshafts with heavy duty 6mm stub axles.
  • Fully ball raced reverse bellcrank steering system.
  • Uses 1/10th AE Offset Stadium Truck or Traxxas Slash Short Course offset wheels.
For you guys all discussing what power plant to run, I would take note of the following statement from Matt W.
Matt - Probably would recommend a 10.5 for something similar to 13.5 in a buggy. I personally run a 6.5 in it and itís pretty fast. Pro4 4600 will run in it but it has a lot of power and will need to be turned down in the esc.
Parts Needed to convert from EB410 to ET410
Pin Replacement Tool options
Inner Hinge Pin Inserts- Degrees of Adjustment
Aftermarket Upgrades:
Print Wikipost
Old 06-12-2019, 04:10 PM
  #931
platgof's Avatar
I got the 22 tooth today and all I can say is wow! I am using a 22T 32P 5MM pinion on a Tekin Pro4 and RSX. It was really amazing seeing how fast it was going. I plan to race this weekend and feeling very confident.
platgof is offline
