Tekno RC ET410 Thread >
Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Like Tree469Likes
Last edit by:
Print Wikipost
Old 07-27-2018 | 09:08 PM
  #196
GIHOSU's Avatar
Speaking of SC wheels, if you don't want to call it Slash offset you can refer to it as Kyosho SC-6 offset. That might makes things a bit better...
GIHOSU is offline
Old 07-28-2018 | 12:47 AM
  #197
RCSteveH's Avatar
Originally Posted by Bubonic-X
what was the reasoning behind doing a 1/10th Truggy instead of a 1/10 short course? There has never been this class why now? And to top it off, that is the most hideous body I have ever seen. Looks like a friggin tadpole
if the body is a smaller version of the ET48, it’s perfect. If it’s not, it’s still perfect too.
Where do I sign up?!!
RCSteveH is offline
Old 07-28-2018 | 10:49 AM
  #198
Stick a stadium truck body on it? Wait for a new one? Not my favorite but no kit body really is lol.
aspiringracer is offline
Old 07-28-2018 | 10:53 AM
  #199
RazorRC's Avatar
I’m guessing with the tall front shock tower, it’s pretty dang difficult to get a body that fits over it that looks good.
aspiringracer likes this.
RazorRC is offline
Old 07-29-2018 | 05:51 AM
  #200
rustyus's Avatar
I'm sure we will see many attempts to make the ET410 platform stand out from stock body crowd. I know I got a couple of Finnisher bodies on hand, and other Finnisher bodies picked out for possible semi cab-forward look.
rustyus is offline
Old 07-29-2018 | 08:13 AM
  #201
I want to get one of these to drive just for fun at the track, and do some mild bashing with. I don't race anymore. I had turned a stampede 4 x 4 into this type of truggy and it was so much fun to drive with SCT tires on it. I can imagine that this would handle better than the Stampede version for sure.
MaX-D is offline
Old 07-29-2018 | 09:07 PM
  #202
I have a brand new Hobbywing SCT Pro ESC and a Tenshock SC411 4000kv motor lying around. Anyone know if they will fit?
gus6464 is offline
Old 07-30-2018 | 04:37 AM
  #203
unlikely. Read some of the early parts of eb410 thread, space is very tight on the chassis for that big of an esc.
blankenj99 is offline
Old 07-30-2018 | 06:31 AM
  #204
totally forgot about that (thanks for the tip!)... I used to race an Ultima SC5 about 8 years ago, though IIRC the foam inserts for Kyosho were very different because the bead would have an angled step down with open cell foams, I don't recall if they ever made closed cell inserts for their wheels or not... I recently started running open cells on the rear and closed cells on the front for turf.
It might be worth running the Kyosho wheels as a tuning option to get a little more fold and get extra grip either on front/rear if necessary... I probably won't need these on turf, but something to consider for those running on medium to low traction conditions.
*** UPDATE
Other SCT's with the same offset:
  • HPI Blitz
  • HoBao Hyper 10SC
  • HongNor Jammin SCRT10
  • RedCat TR-SC10E
I found a "Speedline" series here which give the same "dish" style appearance of traditional ST wheels to help keep the wheels more in line with the spirit of the class:
https://www.amainhobbies.com/de-raci...ps4-uy/p705685
billdelong is offline
Old 07-30-2018 | 06:34 AM
  #205
I'd be willing to bet that Leadfinger will be the first to release a new body just like they did for the EB410... only question is if it will be an ST based body or not???
Old 07-30-2018 | 09:02 AM
  #206
AJH387's Avatar
Bought a Tekin RSX esc. So now I just am deciding which motor. Either going with Tekin Redline 5.5t or 6.5t.
AJH387 is offline
Old 07-30-2018 | 09:48 AM
  #207
boudin4evr's Avatar
tekin Pro2
OR tekin Pro4 NON HD
boudin4evr is offline
Old 07-30-2018 | 09:57 AM
  #208
AJH387's Avatar
Originally Posted by boudin4evr
tekin Pro2
Ya I really like the 4-pole idea. I was a tad worried that it always says those are ideally paired for the RX8 esc though. Any potential issues pairing it with the RSX, long term? I know Matt said they were testing the Pro2 and Pro4 with the RSX but I just felt like I could run into problems down the line.
AJH387 is offline
Old 07-30-2018 | 10:13 AM
  #209
Originally Posted by Matthew_Armeni
Thanks Matt!
Comparing manuals (EB to ET), wouldn't you need 2 parts of TKR7272 drive shafts as the ET uses them front and rear? The conversion page indicates only 1 pair is needed.
Also to note, you use the EB rear shock shaft and body on the front of the ET. Stroke is the same 28mm.
E-Mann is offline
Old 07-30-2018 | 12:48 PM
  #210
FastPete's Avatar
Tekno ET410 is up for Preorder.
https://fiercercsolutions.com/PREORD...it-TKR7200.htm
Price as marked, use the coupon codes to save $$ and free shipping when combined to the 48 states!
FastPete is offline
