Tekno RC ET410 Thread
#212
This new ET410 will probably be a good 1/10 basher but I wouldn't try making the buggy a basher unless you add some of the ET410 parts like the new 32p spur gear because the stock eb410 gear would not hold up to bashing very well.
#213
I would compare the ET410 to the HoBao Hyper10TT.... where that platform started out as a race grade platform about 10 years ago... only problem was the design lacked proper team driver support and very few upgrades were made to it over the years. It has since been a bashers delight for the past 5+ years.
I'm thinking that the ET410 will cater to both racers and bashers alike
#214
for the eb410 I know it was discussed that AE pinions worked best. for this beast, are there any pinions brands we should look at in particular? Looking at a 540 2 pole motor (mine will start as a conversion).
#215
+1
#217
+1
#219
Both 4 pole, yes. And how you explained it is essentially how I also understood the differences as well. Pro 2 a more controlled low end and smooth build. Pro4 harder hitting torque. I could be wrong though.
#221
I run the AE as a rule.. my clay EB410 cam with a Losi, And its been running fine... for what it is worth.
#224
469Likes
