Kyosho Ultima RB6 & RB6.6 Car Thread >
Like Tree172Likes
    Hide Wikipost
Old 12-21-2016, 08:46 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
RB6.6 Kyosho America Product Page: http://www.kyoshoamerica.com/ULTIMA-...T_p_24505.html
RB6.6 Manual http://www.kyosho.com/jpn/support/in...A_RB6_6_IM.pdf
RB6.6 Kyosho Youtube https://www.youtube.com/watch?v=vW_sR667utY
MSRP $639 MAP $399.99
New RB6.6 parts (compared exploded views, prices and links are Kyosho America):
Chassis:
  1. Main chassis - UM731 - $125.99
  2. Side guards - UM732 - $9.99
Battery Holder:
  1. Battery plate - UM733 - $8.99
  2. Battery foam - UM741 - $7.99
Rear Bulkheads:
  1. MM3 and Laydown - UM740 - $9.99
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
3 Gear Transmission (MM and RM):
  1. Transmission - UM734 - $10.99
    • transmission cases
    • spacers
    • caps
    • plastic FR & RR suspension hangers
  2. Gear Cover - UM735 - $6.99
Laydown Transmission (3 and 4 gear possible):
  1. Transmission - UM736 - $10.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  3. Motor plate - UM738 - $18.99
  4. Gear cover - UM739 - $6.99
Body:
  1. Blade body - UMB05 - $27.99
Optional Parts:
  1. Lightweigt Blade body - UMB05LW - $31.99
  2. Aluminum FR suspension hanger - UMW705B - $28.99 (may be able to file UMW705 to fit)
  3. Brass FR suspension hanger - UMW725B - $30.99 (looks more different than UMW725..someone confirm?)
Typical Upgrades for new RB6.6 Buyers
UMW701 Aluminum Steering Plate (RB6)
UMW702 Aluminum Crank Arm (RB6)
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
UMW705B Aluminum Rear Sus. Holder (RF/RB6.6) or brass UMW725B
UMW707 Aluminum Rear Sus. Holder (RR-Mid)
Nice to have:
UMW723 Aluminum Front Sus Block (Type B/10g/RB6/RT6/SC6).
Aftermarket Parts:
Front Wing: https://www.prolineracing.com/perfor...mount-alum-rb6
Print Wikipost
Old 10-10-2012, 07:32 PM
  #1366
Z00M's Avatar
Trader Rating: 15 (100%+)
Originally Posted by mikeyscott
What thrust balls are you using as I have only ever used kit
I order the ones off ebay where you get 50 for A$28 and share them with others. I also order my diff balls that way (100 for $35) but have also used the protek ceramics if you want to try just one set. They are very cheap at around $8 from Amain.
Z00M is offline
Old 10-10-2012, 08:40 PM
  #1367
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Busted the camera out tonight because I feel like we need even more RB6 Pron in this thread! I enjoy this stuff. I bet she will be as fast as she is good lookin
Cpt.America is offline
Old 10-10-2012, 09:41 PM
  #1368
fullsyzz's Avatar
Trader Rating: 121 (100%+)
The Top Racing 1.6 ceramic balls at amain are kickass for the thrust. Or of course bfast is always good too.
fullsyzz is offline
Old 10-10-2012, 09:43 PM
  #1369
umm winning's Avatar
@ Cpt. America What color blue and orange is that? Nice ride!!
umm winning is offline
Old 10-10-2012, 10:05 PM
  #1370
eper's Avatar
Trader Rating: 14 (100%+)
Originally Posted by gelshocker
Sorry for the interruption, I can't let this one go
I probably shouldn't ask this: are your front inner ball studs on the outside hole? I have them in the middle. Caster inserts per manual (0 deg). And I did not get the left and right mixed up
When you say it's dead middle on the hudy, I believe you, as it was with my rb5. Set up per manual, never had to touch them until the ball cups wore out. I don't run front toe-out. If all else fails I'll go with what's worked for me: whatever works. Thanks,
i'm in the farthest hole out on front bulkhead thats what the suplemental sheet called for
eper is offline
Old 10-10-2012, 11:15 PM
  #1371
gelshocker's Avatar
Thanks, I'm starting off with the Tebo nats which calls for the front center hole. Cheers,
gelshocker is offline
Old 10-10-2012, 11:51 PM
  #1372
Orange is fasflorescent orange right out of the faskolor bottle. The blue is a custom mix that I have been doing for a while now. Custom mixed colors is where you get all the good colors . Its actually two blues.. a darker blue around the pinstripes, and a lighter blue in the middle.
Old 10-11-2012, 12:04 AM
  #1373
racer x 1's Avatar
Trader Rating: 27 (100%+)
Ahhh Im nearly done with the build and i can say I havent put together nice of a kit before. and Ive built other kyoshos. I cant wait to do a dialed elec install and get some paint on that body! Ampped!
racer x 1 is offline
Old 10-11-2012, 12:22 AM
  #1374
K_King's Avatar
Trader Rating: 47 (100%+)
Im having a tough time getting the car to rotate on power and even off power. I feel like I have to pitch it on the 180s to get any type of speed. On power exit I just go straight.
Im using Jason's setup with AKA Vektor fronts in Red and Rebars in Red.
K_King is offline
Old 10-11-2012, 02:08 AM
  #1375
Does that tire combo work on your RB5 down there?
I made some more adjustments tonight and went even faster!
Started the night with the setup I posted:
http://mobile.liverc.com/results/?d=...K_BUGGY_NT.xml
Then for round 2 I made some adjustments to get the rear end to be a little more locked in after a 180 coming on power. I lowered the rear shock mount to the furthest inside hole. This helped and I went faster.
Then for the main I felt it was a little to stiff with the shocks down so I went to a softer spring in the rear, switched to gold rear springs, car was amazing for the mains. I was clicking off 19 second laps like it was nothing.
http://mobile.liverc.com/results/?d=...T_(A_Main).xml
Was on a 19 lap pace (which obliterates anytime a stock buggy has gone on that layout, only the good mod drivers or 4wds go 19 laps) but Kevin Smith and I started waiting for each other so we could race.
I'll make a new setup sheet for what I changed tonight and post it up.
Jason.Dias is offline
Old 10-11-2012, 04:00 AM
  #1376
Beasty Shout's Avatar
whatever it is, it looks really good!! Nice scheme!
Beasty Shout is offline
Old 10-11-2012, 05:16 AM
  #1377
rokitman's Avatar
Trader Rating: 128 (100%+)
nice ride
Once I can justify getting one its mine. I picked up a sp2 and a wc earlier in the year so I cant bring self to buy one yet
rokitman is offline
Old 10-11-2012, 05:54 AM
  #1378
Tech Legend
Trader Rating: 1210 (100%+)
[QUOTE=Cpt.America;11311613]Busted the camera out tonight because I feel like we need even more RB6 Pron in this thread! I enjoy this stuff. I bet she will be as fast as she is good lookin
[QUOTE]
wish I could paint I started a body a couple days ago with rattle can and the paint is bad compound that with my lack of painting skill period and EPIC FAIL!
bigwavedave33 is offline
Old 10-11-2012, 06:18 AM
  #1379
Moderator
Posvar's Avatar
Trader Rating: 470 (100%+)
@Brandon...I expect a video of initial launch to be posted!!
Posvar is offline
Old 10-11-2012, 06:22 AM
  #1380
Moderator
Posvar's Avatar
Only got to step 9 last night. Grrrrr. Was hoping for more but it was very smooth nonetheless.
Posvar is offline
