Yokomo MR-4TC SD
#977
Now in stock!
SD Kits and some parts are now in stock at Speedworld Raceway. www.speedworldraceway.com or 916-783-8864
#979
Re: Now in stock!
#981
damn i got to wait till tomorow for mine
#982
does anyone know about the rear toe blocks in the rear is it like the losi where you need to get a new hub to change toe or is like the tc3 where you can just change the rear block ? when will parts like this be out u think ? one more thing how about front Caster Blocks whe will diff Deg be out?? Has anyone raced the car yet out there. IN our area witch is Md Va Dc no one has the car yet...
thanks for any input
#983
THeGame.... I will more than likely be running Mod at the Nats since that's what they want me to run at the track. But I might reconsider and run Stock instead. I dunno yet. How about you?
As for gearing on my BL... I started with 6.9 and might try 6.7 to get alittle more speed out of it so I'm not out run by the 10turns at my other track. It's 145x97 in size. Flowing yet technical.
I'll be running it again tomorrow for some test-n-tune session. I might try that 6.7 gearing on it.
#984
KilRuf
Mod is the only way to go for me, like the speed.. Do you think they are going to have a full straight or what cause from what i heard that is a long a$$ stright. ? Have you gotton your car yet ?
#985
from your last post i see you have it.. sorry..
#986
THeGame, the car is like the TC3 with the toe blocks. The car comes with all of them. It even comes with 1 shim that you can use to either raise the blocks for roll center change. Or another "notched" shim that will allow you to change kickup or squat by degrees!! SpeedtechRC already has the parts online!
I've had my car for what 2 weeks or so. But haven't really raced it yet to where I'm comfortable. But that will change this weekend now that I have a setup that works for Mod. Damn rear droop was kicking my butt!! It was the ticket for me all along!
#987
Woohooo!!!It's here!!!
Sorry guys, I'm just so happy that the Yoke finally here after a couple of months of waiting. I took a picture of it as well as the electronics I am going to use. What do you guys think? Hopefully everything fits without using the top deck.
#988
The straight is 213 feet! Kinda big for electrics! Especially running stock out there where you can have a cup of coffee while the car heads down the straight! haha. The track is long and thin. The straight dominates one side, while the other will be technical. So setting up for gearing will play a key.... do you want speed or punch? Or inbetween?
They have a website... www.thercspeedway.com
#989
WHY NOT CHOICE A GM SX9 ESC? MAY BE U DO NOT HAVE ENOUGH AN EMPTY SPACE.
#990
Damn is that a brand new G10?! Sweet! haha. I have one but it was in my Evo3. It might fit in there. You may have to mount the receiver on it's side. You can gain more room if you feel lucky and mount the servo like I did. Even with a standard sized servo you may gain alittle more room this way. But don't tempt it if you aren't comfortable with drilling and counter sinking 2 new holes in your chassis.
