Hot Bodies TCX
#2281
Andy did an awesome job at TITC, definatly a very friendly guy too, on and outside the track too His car was insane, so much steering and grip, when i first saw him drive it on the practice day I knew it was going to be right up there. Hara and Andy ran very different setups, so it shows that there is more than one way to get the car to go fast. I was pretty happy with my car making the Mod B main in my first international event It was just funny how much the track can change hour to hour, first you have traction roll, then understeer. All a learning experience though
#2282
When will HB start getting back in stock and supporting the TCX. I love my car but am so frustrated with the availability or lack there of on parts. I am ready to sell it and get something else. I only get to drive once a week or so and to miss a week because of parts really sucks.
#2283
What kind of parts are you looking for? I have been able to find almost everything I have needed for the car.
A list of the few places I check and order from........
Horizon Hobbies
Tower Hobbies
Stormer Hobbies
Amain Hobbies
SpeedtechRC
For the normal parts, all these places have what I needed. From bulkheads, to arms, c-hubs, and now DCJ's
Horizon Hobbies
Tower Hobbies
Stormer Hobbies
Amain Hobbies
SpeedtechRC
#2284
Anyone?
Here's are the spring sets you're looking for as well. There's only 2 in stock, if I were you, I would order them asap.
Here's another source.
#2285
1 mm spacers
1.2 mm 3 hole pistons but I understand Tamiya has the same ones that fit and those are at Speedtech
1.5 pivot block
1.0 pivot block
73507 hub set
Thanks for the help
#2286
Just ordered the springs. That's awesome thanks. I still need the following. I will check a few of these other sites but Amain and a few others have been out.
1 mm spacers
1.5 pivot block
1.0 pivot block
73507 hub set
Thanks for the help
1 mm spacers
1.5 pivot block
1.0 pivot block
73507 hub set
Thanks for the help
#2289
I want to know this too...from what I can think of is to get more ride height adjustment. In my case my local track is very bumpy,I need at least 6.5mm ride height to clear the bumps especially at the long straight. I m almost running out of thread on the shock tower trying to get that height, so maybe by using the 2mm lower shock tower, i will get some thread back.
#2290
Hope it helps.
#2291
or you could use a shorter ball end and just have a lower cg
#2293
did anyone try the spec r towers on their tcx? does it make handling any better?
