Team Associated B6 & B6D thread
#1846
Does AE have a metric screw kit that has various different size screws,not car specific? i.e just a spare screw kit to replace any stripped screws and can just be used randomly. Saves buying a pack with a bunch of same size screws.
(Not Ti or steel, just standard kit screws)
#1847
#1848
It was a joke, but not a racist joke. Admittedly not a very funny one. I did explain it, you can look all the terms up on google in 5 seconds.
#1850
Other known online options are fastener express or microfasteners. I'm sure there are others with car specific kits but I forget their names.
#1851
Guys,
Scroll down halfway down the page and the is 4 packs of Ti Screws and that way you can grab certain sizes of button and countersunk ones for spares. You pay about a dollar a screw:
https://www.teamassociated.com/cars_...s_accessories/
If you meant a package of say 2 or 4 of every screw size used in the kit and Ti at the same time then that would be nice to have offered, but maybe just get a second complete set and coupon code it somewhere online to save as best you can.
#1852
KNK has some bulk stuff, not sure if it'll be any help but it's awesome for the vintage stuff Right Here
#1853
In terms of static weight distribution it doesn't matter where and how masses are moved around in the car, it's the final corner weight figures that count. It does increase polar moment of inertia moving the shocks back though. So in proportion to the static weight distribution, 'weight transfer' (as you refer to it) under acceleration is likely reduced, at least transiently.
It matters where the weight is because weight is really just gravity. Weight is measured at each corner of the car in a static environment and that's where you get your corner weight values. That environment is a safe place like a workbench and a scale, but that isn't where we race.
Corner weights are a good overall metric because it's very hard to measure dynamic forces at play on the race track, but to pretend like those dynamic forces don't exist is a bit silly.
Once you get into that dynamic environment (like a race track) then center of gravity is at play as is dynamic weight distribution (weight transfer) which is impacted by center of gravity. Adjusting the shock locations impact center of gravity and adjusting shock locations outside of the wheel base also has a added bonus of pendulum effect is can have. Take for example a rear motor buggy and their tendency to spin as compared to a mid motor buggy. In the case of rear mounted shocks, it is also an impact regardless of how minor.
So what do you do when you can't effectively measure those dynamic forces? You experiment and go with what feels best. It's best to understand what basic impact the changes have so you know which direction to go in. My intent was to describe those impacts.
The impact of the weights as I described them are accurate, and I argue that people understood (even though you said it was a terrible explanation). Once I see a manufacturer's tuning guide that tells it's kit owners about polar moments and such versus the impact of the adjustment then I will concede that you explanation is superior.
Until then, enjoy your formulas.
#1854
I wrote a long and boring reply but deleted it and will be straight to the point with this one, not aimed at you of course.
Front of the arm vs rear of the arm? Try both and see for yourself which feels better if it feels better and the clock agrees it's the better of the two.
#1855
- Rear of arm = More weight transfer to rear on acceleration/more forward traction/less on power steering
- Front of arm = Less weight transfer to rear on acceleration/less forward traction/more on power steering
If that's not accurate, then what is it? You and Ant keep saying I'm wrong, but aren't providing what the impact of shock locations is.
I can only assume you guys are saying it's the opposite of what I said, so it sounds like you guys saying that shocks on the rear give more on power steering and less forward traction? Shocks on the front give less on power steering and more forward traction?
I don't get it.
Isn't that what I said? "You experiment and go with what feels best."
#1856
Hey guys, I summed up the feeling in a single post. We all have better stuff to do than argue about the science behind it.
#1860
Super Moderator
Trader Rating: 31 (100%+)
Technical this or that, this language that language (I say Google terms you don't understand)..."racist", give me a break
At the end of the day, just ask yourself. "What would Wildcherry say?"
The answer...Nobody knows, most people can't read "smoke"..except maybe Cheech and Chong.
