Hot Bodies D413 1/10 4WD Buggy >
Like Tree66Likes
Old 04-28-2015, 12:52 PM
  #9001
Trader Rating: 49 (98%+)
What are you guys running for diff fluid in the center?
wheres_yogi is offline
Old 04-28-2015, 01:55 PM
  #9002
Vinny Cancilla's Avatar
Ty is not running the kit chassis. So it is not that perfect, lol. Otherwise, my main issue was shotty parts support and really soft plastics.
What chassis is Ty running? He said he would only run the Avid chassis on very high bite.
Vinny Cancilla is offline
Old 04-28-2015, 01:59 PM
  #9003
Tech Prophet
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
HB prototype. He told me at cactus he runs the proto everywhere. But, if you are running high bite and dont have the proto, he felt the avid was the best. He suggested I use the avid for cactus, since the prototype chassis was not out. This was from his mouth, not some info a guy who knows a guy.
Wildcat1971 is offline
Old 04-28-2015, 02:29 PM
  #9004
Team Tekin
yzracer758's Avatar
Trader Rating: 18 (100%+)
Here are some new parts available for your D413 from Factory-RC Products. Center diff mount: counter-sunk screws make a clean finish.
Shorty battery brace: has negative and positive markings on the ends to help prevent any reverse polarity accidents. Can be flipped to accommodate different battery configurations.
Rear camber plate: additional holes for more tuning options as well as lighter over stock piece.
Attached Thumbnails Hot Bodies D413 1/10 4WD Buggy-%5E2a07c17215c178679a3b2f5543982a9ac8b97445bfa4eeac46%5Epimgpsh_fullsize_distr.jpg   Hot Bodies D413 1/10 4WD Buggy-%5E6ab688777bb2230035d126c9148779c8f06ae228d9bad6489f%5Epimgpsh_fullsize_distr.jpg   Hot Bodies D413 1/10 4WD Buggy-%5Ebc59d221676414c30602826900f06182aaeaae864c86f1b304%5Epimgpsh_fullsize_distr.jpg
yzracer758 is offline
Old 04-28-2015, 04:09 PM
  #9005
Schwarta's Avatar
Didn't they originally make a carbon rear camber plate but it kept breaking? So had to make it alloy? Is this one going to be strong enough?
Schwarta is offline
Old 04-28-2015, 04:23 PM
  #9006
Tech Prophet
I got excited about new center diff mounts..... then I looked and realized it is just a cap. I would prefer motor mounts that let you take the center diff up and out like everyone else. a cf center caps is..... well lame.
Old 04-28-2015, 05:20 PM
  #9007
Yeti AS3's Avatar
Trader Rating: 77 (100%+)
With the Schelle chassis (only one I tried), you can take off the front top brace, front diff mount, and fenagle the diff forward and out the top. No moving motor or removing the rear mount.
Yeti AS3 is offline
Old 04-28-2015, 05:25 PM
  #9008
Tech Prophet
Still. Kinda lame. Maybe the 2016 car will improve that
Old 04-28-2015, 06:09 PM
  #9009
Team Tekin
yzracer758's Avatar
No issues running this piece. It is 3mm thick btw.
Old 04-28-2015, 11:11 PM
  #9010
nitro2be's Avatar
10 100 5 it's great indoor clay
nitro2be is offline
Old 04-29-2015, 05:50 AM
  #9011
snwchris's Avatar
Too open ended... really depends on your track conditions and material.
For most of the tracks I've been to in NE OH, I run 7-100-5 and that car feels super planted. My home track is Med-High bite clay mixture and we run M4 Electrons and Ions
snwchris is offline
Old 04-29-2015, 06:51 AM
  #9012
Medium size outdoor track. Clay base that does get rough as the day goes on. Some 90 degree turns and 5 180 degree turns. Tends to get dusty later in the day. Lap times were running about 30 seconds per lap.
Old 04-29-2015, 07:07 AM
  #9013
Team Tekin
yzracer758's Avatar
Typical rule of thumb I use for center diff.
Low-Medium Traction: 60k center fluid
Medium/High- High Traction: 100k center fluid.
Old 04-29-2015, 07:51 AM
  #9014
Trader Rating: 12 (100%+)
I just wish I could get a clear explanation of why the Avid chassis would be better than stock for high grip. From what I've read, it doesn't really do anything other than add weight and give options for adding even more weight, which I don't need.
-Chris
iScream is offline
Old 04-29-2015, 07:55 AM
  #9015
Tech Prophet
-Chris
Lower CG and less flex.
