Hot Bodies D413 1/10 4WD Buggy
#4246
Something that has been bugging me. Looking at Tessmans setup sheet for OC/RC there are two places that show toe in settings. The picture with 5mm on rf block and 2mm rr block, but then there is a box with rear toe in settings saying to use .5mm rf block and 2mm r/r block. Which is correct? And if the diagram is not for toe in settings what is the 5mm of washers for? Totally confused now that I typed it out.
#4247
does anybody know when kits will be at retailers? Amain showed today as a eta?
but have since taken the eta date down?
thanks
cant stand waiting :}
thanks
#4248
I totally agree that the stock shock caps were a bad idea, and if you want to sell your car go ahead, but I don't understand the hate toward the B5 cap fix. They are cheap, easily available, and fit right on. If they decrease the droop a tiny amount, then just unscrew the shock end a quarter turn and you are back in business.
It does seem that the rear outer ballcups on the camberlink have broken for several people (myself included). I wonder if there is anything that can be done to strengthen that area.
#4252
it seems like most of the kits and parts for that matter that are making it state side are just filling back / pre orders and so they never make it to the "in stock" status.
#4253
edit: damn b10
#4255
How are b5 shock caps limiting droop?
#4258
With the help of Billy Fisher, we have determined that the B5 caps make the shock top 0.50mm shorter over stock. You can change this at the shaft length with no major effect. Also note that the standoffs for the b5 might be shorter then Required. I added an additional 1mm shim to compensate. As long as the cap has side to side play then it is good. Been running them for almost a month. Zero issues.
#4259
If the Ae caps lower the shock a bit, that will only help smooth the steering a little .
Just remember to unscrew the shock eye for the jumps.
#4260
Does anyone have a pic of the b5 shock cap mod I'm hoping my kit will be in this week cant wait.
