Xray XB4 thread
I have gone through and calculated the rates and have them marked on a chart at home. I'll post up what I think they compare to. Remind me if I forget.
Springs help
Let me try to help for people wondering about xray springs.
If you multiply the xray spring rate by 5.71, you will get the rate that most every other manufacturer uses.
For example:
Front springs - Linear 1dot C= (I only see an xb2 1 dot spring and don't know if it would be the same for the XB4)
Front springs - Linear 2 dot C=0.65 or 3.71 lbs/inch
Front springs - Linear 3 dot C=0.72 or 4.11 lbs/inch
Front springs - Linear 4 dot C=0.80 or 4.56 lbs/inch
Rear springs - Linear 1 dot C= .35 or 1.99 lbs/inch
Rear springs - Linear 2 dot C= .40 or 2.28 lbs/inch
Rear springs - Linear 3 dot C= .45 or 2.56 lbs/inch
Rear springs - Linear 4 dot C= .50 or 2.85 lbs/inch
The link below has most of all springs on one chart for reference.
http://site.petitrc.com/reglages/BuggyBigBoreSpring.pdf
Hope this helps.
For example:
Hope this helps.
You are correct my friend. They must have just arrived as I know a lot of new parts were listed in stock yesterday but the 1 dot rears were listed as out of stock. Thanks for the heads up my friend.
Symmetricon,
Thank you for the offer my friend I greatly appreciate it. No need to check to see if you have extras as Amain has them listed in stock as we speak.
Thanks Fellas as always the help on this thread is greatly appreciated.
Symmetricon,
For example:
Hope this helps.
For example:
Hope this helps.
If I had to guess, it's probably around C=.59 or 3.36 lbs/inch, but I'm totally guessing.
http://forum.teamxray.com/viewtopic.php?f=101&t=13202
*** Anyone running the Cactus Classic in a couple weeks? ***
On the xray Brano Bulko says it's: Front Linear 1dot C=0.65
http://www.amainhobbies.com/rc-cars-...368184/p247435
Symmetricon,
Symmetricon,
Has anyone tried using the new bulkhead from the 16 on the 15? Does it work. I'd like to get the extra durability if possible.
I saw that, but I don't think that Brano is correct. Here is a link to a picture of the springs. There is a picture of the package which shows the C rate.
