Team Associated TC4
#8446
Originally Posted by dr_hfuhuhurr
Associated's balls are steel
It's really not that big of deal.
#8448
sorry i idnt know ball stud are made of steel, i thoght they are made of alu (get the infor from towers)
http://www2.towerhobbies.com/cgi-bin...I=ASCC6276&P=7
#8449
#8451
It's really not that big of deal which ballstuds you use. So long as they work with your setup (long neck vs short) use what you want.
#8452
am3 how many ballstud it have for the tc4?, could u list them off. thanks again
#8453
2 - 3981 short neck black ball stud .200" (servo arm/steering rack arm)
all other ball studs on the car are .300" long neck silver ball studs #6277
(4) - inner camber links
(2) - steering block/steering link
(2) - steering bellcrank
#8454
thanks for the info
#8456
I orginally tried to use RPM ball cups, but because they are so long I could not get my camber and toe in right. I even cut some of the length off, but that left very little to hold the threads. I eventually went back to the Associated ball cups, but the ball cups from Lunsford, might work and be stronger.
Has anyone used ball links?
#8457
I have the schumacher ones. Definitely stronger than the associated ones. I haven't tried the other brands though.
#8458
I've been using RPM ballcups to help reduce slack the steering links. You have to cut about an 1/8" off the length and clearance around ballcup so they don't rub anything. Cut them down to the same length from ball center to the end of the cup as a stock associated ballcup and you should be ok as far as maintaining the same thread engagment.
#8459
Have you guys tried the AE B4/T4 ballcups? I have had no problems with the stock ones but, I have a friend that replaced his from the start and has had no problems. There again you would have to trim them down so they do not rub.
Later
Kevin Boyle
Later
Kevin Boyle
#8460
Can anyone tell me the internal ratio of the TC4, specifically the Factory Team version?
