Tamiya TRF416 / TRF416WE / TRF416X
#6946
For the steering on my car I replaced them with the new Xray steel ball studs they are 8mm studs and with the cups a pretty slop free and strong to boot. I think if you go back a couple of pages Syndrome posted the part numbers for the Tamiya ones.
#6947
#6949
Axle Length?
Sorry I've never used the 3Racing blocks but you would expect that they would have done a half decent copy job!
AXLE LENGTH
Can someone please tell me the length of the Tamiya axle? I'm after the total length of just the shaft area. Unfortunately I dremelled mine down so I don't know for sure... Thanks.
AXLE LENGTH
#6951
From what I've seen the 3R blocks tend to have a little more material around the bushing area and this could cause clearance issues depending on where you are using them
#6953
What are you looking for as far as a measurement goes? Is this the "dog bone" or the axle that you want the measurement off of?
#6955
#6956
Did you get a set yet? I'm thinking about trying them too, but have the same concerns, although 44 is better than the 42 stock unit.
#6957
#6960
I wonder if the pins are a problem, if you could replace them with piano wire replacement instead of the ground pins? I'm speculating the piano wire would be less brittle so maybe they could take the shock better. I would also do the LOSI shrick wrap deal on them to keep the pins in. JMO
