Tamiya TRF416 / TRF416WE / TRF416X >
Like Tree4Likes
Old 03-15-2010, 08:59 PM
  #8446
Originally Posted by Geppetto View Post
Thanks Karl. I still have a lot to learn.
Hey Geppetto,
When are you going run the 416x? Are you running 17.5 or 13.5 with it? I got one for Christmas and i'm just starting to learn it.
Adrian
M3dreamin2008 is offline
Old 03-17-2010, 01:23 AM
  #8447
HK416's Avatar
Hi, I've just got my 416X and I've run it with the Demon Lipo tray . The car feels good and tracks very well. If I don't want to run with the tray, how should balance my car . How much weight should I put and where should I place it? Your advises is much appreciated. I bought the car used and comes wt the tray.
HK416 is offline
Old 03-17-2010, 02:16 AM
  #8448
CraigM's Avatar
Trader Rating: 34 (100%+)
It depends on the weight limit in your country and the electrics you run. I have 70g down the outside of my lipo and that's balanced at 1430.
CraigM is offline
Old 03-17-2010, 02:49 AM
  #8449
HK416's Avatar
The weight limit here is 1400gm.
HK416 is offline
Old 03-17-2010, 09:31 AM
  #8450
Ritchie T's Avatar
Exclamation
Hi i have a few questions:
1. Which brands of 48dp spur gears fit the 416x?
2. How big of a 48dp spur gear will fit?
3. Also what is the equivalent of a 105 tooth 64dp spur in 48dp?
Ritchie T is offline
Old 03-17-2010, 09:58 AM
  #8451
Trader Rating: 118 (100%+)
Welp... Have my new 416x on the way! Got a great deal from the LHS. Now... I really want that Ecotek chassis that is out of stock! Anyone try this chassis? Comments?
Chris Furman is offline
Old 03-17-2010, 10:08 AM
  #8452
I'm using hpi racing 78t 48dp spur.
78t is very similar to the 105t 64dp,maybe a bit smaller.
I could use pinions from about 20 to 32t.
A 79t could fit but not a 80t because my 78t is very close to the hole on the lower deck.Maybe a 79t needs some shaving from the lower deck.
HPI,Hot Bodies,yokomo and Kawada will fit but i think xray spurs are not.
Davzone is offline
Old 03-17-2010, 10:53 AM
  #8453
John_S's Avatar
rw and kimborugh gears also fit
John_S is offline
Old 03-17-2010, 11:52 AM
  #8454
RC MARKET's Avatar
RW is ok !
RC MARKET is offline
Old 03-17-2010, 03:01 PM
  #8455
what I found out is that you need asia based companies (kawada, xenon, hpi) if you want to use all four mounting screws. If you go with kimbrough, RR, PRS, you can only use 2 out of the 4. The center hole is pretty much the same. If you tighten the 2 holed ones too much, the spur will start to warp. So I use the xenon ones exclusively.
redbones is offline
Old 03-17-2010, 03:08 PM
  #8456
veecee's Avatar
Agree with redbones on this one. I like the HPI glass-filled spurs because they are nice and stiff so they are harder to warp and the 4 holes are spot on. I've been using those since the Pro2 days! But they only do them in steps of 3 teeth... And 81T just fits with a teeny bit of clearance.
veecee is offline
Old 03-17-2010, 03:46 PM
  #8457
syndr0me's Avatar
Trader Rating: 32 (100%+)
Would it kill Tamiya to drill the center pulley so it'll work with any hole pattern?
syndr0me is offline
Old 03-17-2010, 05:25 PM
  #8458
CraigM's Avatar
HPI and Xenon spurs are identical apart from colour
Can someone confirm what the biggest size 48dp spur you can run on the 416 is? I'm currently running 76t but with the new tekin software my motor is right up against the motor mount using a 17t spur
CraigM is offline
Old 03-17-2010, 05:34 PM
  #8459
veecee's Avatar
veecee is offline
Old 03-17-2010, 05:36 PM
  #8460
veecee's Avatar
I'm running 81T at the moment. Just clears on the Tamiya chassis but I beveled the slot slightly just in case. There is slightly more clearance with the Smokem chassis.
veecee is offline
