Tamiya TRF416 / TRF416WE / TRF416X >
Like Tree4Likes
Old 11-16-2009, 01:14 PM
  #7096
Johnny Wishbone's Avatar
Originally Posted by Stilo
With these big diameter Xenon tires diffs up seems to be the best option to have to get the driveshafts runing more lined up, so clearance to the chassis is not a problem. I think there will be enough gap even when running diffs low. There is also a possibility that rear diff will come loose as it is running another direction from what it is designed for, hopefully it wonīt..
Picture after the mod
Iīm really looking forward to test my car in this setup.
Unless you space the top shock mounts with washers when you run the diffs high it will rub on the mount, the rear one might work but the front will definately have clearence problems.
Johnny Wishbone is offline
Old 11-16-2009, 04:52 PM
  #7097
Stilo's Avatar
You need to take some material off the upper bulkheads in front, as spool outdrive sleeves will rub to the bulkheads under the upper link mounting points. A bit of work with dremel tool and itīs fine. Pulley is not even close to the actual shockmount.
And for the top deck:
Stilo is offline
Old 11-16-2009, 05:25 PM
  #7098
yokemad's Avatar
Thanx a lot Dude
yokemad is offline
Old 11-16-2009, 07:59 PM
  #7099
jonest's Avatar
I wonder the effect of this method same as removing 4 screws (rear:2 / front: 2) from the top deck; as I think both methods would increase chassis flex.
I did this, I have tonnes of steering and the car is very easy to drive. I lower the roll centre (front: 3mm / rear: 3mm), the car is responsive and faster thru the corners. Any1 tried?
jonest is offline
Old 11-16-2009, 08:05 PM
  #7100
correcaminos's Avatar
Easy question , I bougth a trf 416 we used . Where can I find the owners manual.?
correcaminos is offline
Old 11-16-2009, 08:15 PM
  #7101
jonest's Avatar
I think u cam try Tamiya USA website
jonest is offline
Old 11-16-2009, 09:35 PM
  #7102
CraigM's Avatar
Trader Rating: 34 (100%+)
I would think the car would tweak easily with only 2 screws in the front
For those cutting your decks, just keep in mind that you can go too far with making the car flex, and if that happens you'll lose corner speed and stability, especially in sweepers
CraigM is offline
Old 11-16-2009, 10:11 PM
  #7103
http://www.tamiyausa.com/pdf/manuals/42138ml.pdf
gimpex is offline
Old 11-16-2009, 11:20 PM
  #7104
Thanks , now which is the front end ?
I had race off road for some time now and I'm learning the on road craft ,I wish races were longer .One mistake and you are B main.
Old 11-17-2009, 12:18 AM
  #7105
entitymugenmtx's Avatar
Trader Rating: 85 (100%+)
Wanted to know where I can pick up a set of diff cover stickers
thanks David
entitymugenmtx is offline
Old 11-17-2009, 01:00 AM
  #7106
thanks David
Is this what you looking for ? 53970
http://www.rcmart.com/catalog/rc-trf...0-p-24633.html
gimpex is offline
Old 11-17-2009, 06:04 AM
  #7107
yokemad's Avatar
Stay away from RcMart These guys are Too Slow !
2 days past and my orders still not Posted I do recommend RCMARKET never had to wait that Long with them
yokemad is offline
Old 11-17-2009, 06:10 AM
  #7108
yokemad's Avatar
Thats what I'm worrying about ....
Cutting rear only sound like a better idea
yokemad is offline
Old 11-17-2009, 06:22 AM
  #7109
Stilo's Avatar
Well it worked really good all over the track on high grip conditions and it was tested with almost 10 different drivers and everyone thinked that it was a big improvemet. So the risk of the mod not working seems to be low, and you can just buy a new top deck for a bit over 10$ to have less flex if needed.
Stilo is offline
Old 11-17-2009, 06:25 AM
  #7110
Keith Billanti's Avatar
Trader Rating: 15 (100%+)
anyone know of a US based company that carries 4 degree castor blocks in aluminum? (3 racing or the like)
I went through 5 carbon caster blocks this past weekend.
also need spoolcups...
Keith Billanti is offline
