Like Tree1Likes
Xray T3 2012
Old 02-29-2012, 06:05 AM
  #1636
bozzplayer's Avatar
Trader Rating: 17 (100%+)
Originally Posted by theatriks
Its on its way .....but if u knew how to read u would see i said "apparently" which would mean i dont own one myself ....but we can go over the english language next race day if u like
lol, sound like fun, but before u teach me the English language how about you try and CONQUER driving in a straight line without hitting everything around you
bozzplayer is offline
Old 02-29-2012, 07:40 AM
  #1637
theatriks's Avatar
You might actually want to try and make an A main before u start talking like that...
theatriks is offline
Old 02-29-2012, 07:51 AM
  #1638
locked's Avatar
So, both of you guys(bozzplayer and theatriks) are coming to the Canadian Onroad Nats, in less than 2 weeks, to show us all your skills, right? :P
locked is offline
Old 02-29-2012, 08:05 AM
  #1639
theatriks's Avatar
I cant make it ....but u will know who sam is ....just look at who makes the D main and he should be rite in there lol......and if thats not enough just look for the loudest guy there
Old 02-29-2012, 08:27 AM
  #1640
R40Victim's Avatar
I recently broke my car, and the factory replacement is out of stock:
http://www.amainhobbies.com/product_...int-5mm-Open-8
Will these work in stead?
http://www.amainhobbies.com/product_...ctional-Open-4
R40Victim is offline
Old 02-29-2012, 10:03 AM
  #1641
Skiddins's Avatar
Yes, I would look into changeing to these in future;
http://www.amainhobbies.com/product_...Joint-w-Hole-4
Which will require you to use these instead of screws;
http://www.amainhobbies.com/product_...w-6mm-Thread-2
With 10mm versions for the C-Hubs.
Skiddins is offline
Old 02-29-2012, 10:32 AM
  #1642
M-Technic's Avatar
Trader Rating: 15 (100%+)
I actually miss the pass-through ball cups with screws from the 2012. It made it much easier to changing the shimming of the links, since you could change the length of the screw accordingly.
M-Technic is offline
Old 02-29-2012, 10:37 AM
  #1643
R40Victim's Avatar
Thanks, but those are out of stock as well. Is there an upgrade or something that does the same job?
Old 02-29-2012, 11:35 AM
  #1644
syndr0me's Avatar
Trader Rating: 32 (100%+)
syndr0me is offline
Old 02-29-2012, 11:38 AM
  #1645
artwork's Avatar
Trader Rating: 88 (100%+)
Originally Posted by syndr0me
Those look very nice!
artwork is online now
Old 02-29-2012, 11:41 AM
  #1646
haywood's Avatar
Trader Rating: 49 (100%+)
Default Shocks
Nice! I may make the switch also to Tamiya/Exotek!
haywood is offline
Old 02-29-2012, 12:06 PM
  #1647
Fred Hubbard's Avatar
The 2nd option is best when used with our ball studs because you will have a flat plane across the top without any concern like you would if you were using the stock 2012 ball cup or the 2011 ball cup with a screw rubbing on the rim and you can run more shims if you choose as well.
Fred Hubbard is offline
Old 02-29-2012, 12:07 PM
  #1648
locked's Avatar
Those do look really nice. I'll probably stick with the kit ones though.
I never thought I would say this before owning a T3, but I actually like the kit plastic shocks. They seem to last longer before requiring a rebuild than the aluminum shocks I've used in the past and the shafts don't get scratched up so easily.
locked is offline
Old 02-29-2012, 12:52 PM
  #1649
orci77's Avatar
Originally Posted by EAMotorsports
Alexander Hagberg ran it at the Snowbirds and runs it pretty much everywhere. He seems to think its better in pretty much all conditions. Ive ran the thin top deck but not the chassis yet. Top deck does give more traction by itself.
EA
In Xray forum it was said that he was NOT running the 2,0mm.
orci77 is offline
Old 02-29-2012, 01:03 PM
  #1650
Skiddins's Avatar
I do quite like the plastic shocks but I'm currently in the process of converting mine over to alloy.
I found that once the plastic shock body's get some grit or muck in the threads on the shock body, the adjuster gets stuck easily and then the threads get ground down which just makes it all even worse. THe alloy shocks put up with muck a bit better.
Skiddins
Skiddins is offline
