Xray T3 2012
#1606
Im looking for a full set of the spec r bulkhead clamps if anybody has some they want to sell let me know .
#1609
Doesn't look like it... the outside servo mount just doesnt bolt to the chassis leaving a small gap. Better pictures on Xray's website... http://www.teamxray.com/teamxray/new...&kategoria=738
#1610
Hi guys
I have a noob question which I am sure has been answered in the past but I am hoping since the brushless motors have been around for longer now I can draw on some of your experiences.
Basically I am looking for a 17.5 sensored motor for my xray T3 thats fast and reliable and doesnt get too hot as I am in Adelaide and the weather here can sit above 30C for long periods of time.
I have tried to find a Corally 17.5 pro red but they dont make them anymore.
Any suggestions or opinions would be welcome and dont hesitate to point out any motors that are crap
Marius
Marius
#1611
Hi guys
Marius
Marius
#1612
Anyone have try Arrowmax CVD's? Is it good compare to Xray Ecs?
#1613
I ran them for about a month, very good product...But as I can tell from their website they only offer 52mm sets, and not 50mm. I ran metal spool outdrives and clipped a corner, not really that hard, and the Arrowmax CVD pin shattered. I rebuilt it with the XRay pins, with the flats, and it is good as new. All in all great product for half the price.
#1614
so, its safe to assume that the arrowmax ecs use the same pin size as the xray ecs, 1.5x8 in board and 1.5x9 out board, would this be correct thanks
#1615
Yes the Arrowmax ecs' use the same length pins as the X-Ray...Although this past Sat. at the Hurricane race in Indiana I used the 1.5X9 pins (as I did not have the shorter length pins) for the entire ECS. clearance was tight, but as long as you are using the ground flat spot pins you should be fine...I triple checked to make sure that there was not any binding issues with the extended pins by compressing the arms and by also turning wheels to full lock right and left...a dremel could alleviate this issue, but I had enough clearance for this to not be a problem.
#1616
thanks, how about the 2.0mm chassis anyone try it and is it better, I am about to order some parts and want to know if its worth buying
#1617
Does anybody upper bulkhead clamps yet have the new calandra vbc ?i would like to know the height compared to the xray ones.
#1619
