Like Tree1Likes
Xray T3 2012
Old 03-01-2012, 01:56 PM
  #1666
haywood's Avatar
Trader Rating: 49 (100%+)
Default Setup
I have been running the +75 hexes in the front and the -75 hexes in the rear for sometime now. What should I notice by going back to the stock hexes all around? Thanks
haywood is offline
Old 03-01-2012, 01:58 PM
  #1667
artwork's Avatar
Trader Rating: 88 (100%+)
Honestly probably not much difference if you change both as this will somewhat offset each other.
artwork is offline
Old 03-01-2012, 01:59 PM
  #1668
bozzplayer's Avatar
Trader Rating: 17 (100%+)
Originally Posted by theatriks
You might actually want to try and make an A main before u start talking like that...
Not only do i make the Amain i always seem to reset tq every other round
but nice to know that your trying to get fast enough to make the amain or even the B main, I'm sure ur employer Great Hobbies is thrilled to have a guy drive for them that makes the C main all the time
see you sunday at the race Rob
bozzplayer is offline
Old 03-02-2012, 01:16 AM
  #1669
Trader Rating: 23 (100%+)
Narrow the front track width and you'll get a little more front grip/steering. Widen the rear track width and you'll get a little less rear grip and more on power steering. So it's gonna change the car a lot depending on the rest of your setup. I've tried different track widths front and rear on both of my 2012 cars, it's a fairly significant adjustment on this car, IMO.
pcar951 is offline
Old 03-02-2012, 08:08 AM
  #1670
+1
What do you think the difference is in narrowing on the inside/Hagberg style vs. using narrower hexes outboard?
Emil is offline
Old 03-02-2012, 08:14 AM
  #1671
Dane's Avatar
Trader Rating: 26 (100%+)
Originally Posted by Emil
+1
Narrowing at the suspension blocks makes the upper camber length shorter. Hexes only change width, not camber link as well.
Dane is offline
Old 03-02-2012, 09:10 AM
  #1672
orci77's Avatar
Originally Posted by tak4
Hey guys, just got myself a T3'12 and was just wondering how to the plastic shocks hold up in crashes. Do they pop off easily and is there a true need to upgrade to aluminium parts?
Cheers for any input provided.
Three hours into the build and I'm loving it.
They should survive crashes. Only once a friend of mine had a brocken shock body. But this is one case in over 3 years. So dont bother about this.
I upgraded to alu shocks too.
They feel better. But most important for me: they are much more forgiving on curbs which is nice on our tight indoor carpet track.
orci77 is offline
Old 03-02-2012, 10:03 AM
  #1673
R/C Tech Elite Member
Jamison R's Avatar
Trader Rating: 66 (100%+)
What aluminum shock bodies are used? I am new to xray and interested in the alu shocks. Are people useing the trf shocks with exotek caps and collars? Or is there an actual xray alu shock body?
Jamison R is offline
Old 03-02-2012, 10:12 AM
  #1674
defcone's Avatar
Trader Rating: 15 (100%+)
For xray shocks.
defcone is offline
Old 03-02-2012, 12:23 PM
  #1675
UrabusDenis's Avatar
I've had my first two training days and I must say the car is superb to drive, the problem being the pins in the joint came loose two times in 6 batteries resulting in them rubbing the plastic (hope you understand the problem?). I have now flattend them as someone posted before, so I hope it will work now.
UrabusDenis is offline
Old 03-02-2012, 01:10 PM
  #1676
tak4's Avatar
Hit a stumbling block while completing my build yesterday.... One of my drive shaft isn't threaded. The others are ok...
Kinda made me lol a bit before realising I'd have to wait longer before getting my car on the track... T_T
tak4 is offline
Old 03-02-2012, 01:26 PM
  #1677
Trader Rating: 19 (100%+)
i clicked on the pic before reading the post and i instantly was like it doesnt look threaded thats a shame man!
COLD AS ICE is offline
Old 03-02-2012, 01:48 PM
  #1678
tak4's Avatar
Yep... It's unfortunate. And the build was going so smoothly too. Just my luck these days...
tak4 is offline
Old 03-02-2012, 04:25 PM
  #1679
Xpress's Avatar
How does that slip thru qc?
Xpress is offline
Old 03-02-2012, 05:17 PM
  #1680
Jamison R's Avatar
Originally Posted by defcone
For xray shocks.
Is there a part #?
