Like Tree1Likes
Xray T3 2012
Old 03-11-2012, 05:28 PM
  #1786
Default HPI Springs?
Hello guys, today I went to the track (Asphalt) car was great except for a couple of cvd issues... I am looking to make the car handle a bit sharper and planted, would like to start by replacing the springs with HPI ones. I heard Silver and Pink work great on asphalt (High traction) but I am open to other suggestions, I would like to have a parts number of the HPI springs used on the T3.
Thank you!
arix is offline
Old 03-11-2012, 08:14 PM
  #1787
dr_hfuhuhurr's Avatar
Trader Rating: 93 (100%+)
Heavier diff oil in the rear gear diff does what?
dr_hfuhuhurr is offline
Old 03-11-2012, 09:32 PM
  #1788
Robertcooper88's Avatar
Trader Rating: 15 (100%+)
it will Free up the rear end. Less Diff action.
Robertcooper88 is offline
Old 03-11-2012, 09:57 PM
  #1789
narcotiks's Avatar
Racing in 21.5 boosted on a high grip ashphault track , wanting to get some ecs drive shafts. I'm running the 52 mm stock ones now , what should I get , 50mm ecs or 52 mm ecs
And you only need them for the front correct?
narcotiks is offline
Old 03-12-2012, 05:10 AM
  #1790
Hi Skiddins,
Ian has only tried the 1.6 topdeck indoors on carpet but it definitely gave more steering.
donwhit is offline
Old 03-12-2012, 05:38 AM
  #1791
Skiddins's Avatar
Originally Posted by donwhit View Post
Hi Skiddins,
Cheers.
I don't actually need any more steering indoors, but was interested in other people's testing.
Looks like I'm going to have to get a 1.6mm top deck to test at WLRC
Skiddins is offline
Old 03-12-2012, 05:51 AM
  #1792
jgraham37128's Avatar
Trader Rating: 25 (100%+)
Originally Posted by Danny-b23 View Post
Smooths out the front end, in my opinion.
It's because the front end is usually spaced out wider than than the rear end. When the front end is wider, the drive shafts don't go into the plastic outdrives far enough and will cause them to break very easily. If you go to 52mm's it solves the problems. Everyone I know runs 52mm in the front and 50mm in the rear for this reason.
jgraham37128 is offline
Old 03-12-2012, 06:35 AM
  #1793
Skiddins's Avatar
Thank you!
HPI 6543 (Silver)
6548 (Pink)
Might be worth getting two pairs of silver so you can run the same front and rear
Skiddins is offline
Old 03-12-2012, 09:54 AM
  #1794
Default Rear suspension block
Im looking at getting the one piece rear suspension block (302048-O) to sort out the rear toe issues! I was just wondering will this definitely give you an even toe left to right and will i notice any difference in the cars handling?
Matt W is offline
Old 03-12-2012, 09:57 AM
  #1795
kuruption's Avatar
Trader Rating: 24 (100%+)
Have you tried to shim the two sides to be even? Did you notice a difference? That's what I did, now they are within maybe 0.25 degrees, and I do not notice much of a difference left to right.
kuruption is offline
Old 03-12-2012, 10:01 AM
  #1796
Fred Hubbard's Avatar
Heavier = more on-power steering, less initial steering and rotation
Lighter = more initial steetring, less on-power steering and rotation
It will help with you with your toe issue and you will loose some rear traction.
Fred Hubbard is offline
Old 03-12-2012, 11:06 AM
  #1797
gonzo416's Avatar
Trader Rating: 39 (98%+)
Anyone tried this chassis in the RCGT class? If so, what setup. First time running it with belted HPI X-Pattern tires and it is garbage. I'm on the podium but it's definitely not any thanks to setup. It could be that I'm used to running regular rubber tire. I almost have no choice, rubber tire TC is dying where I race.
gonzo416 is offline
Old 03-12-2012, 11:13 AM
  #1798
I found belted X-Patterns to be very loose unless they were sauced and baked
DOTMAN is offline
Old 03-12-2012, 11:18 AM
  #1799
gonzo416's Avatar
With tire warmers?
gonzo416 is offline
Old 03-12-2012, 11:20 AM
  #1800
With tire warmers?
No...put them in the oven
of course tire warmers!!
DOTMAN is offline
