Schumacher Corner
#9046
Originally posted by Jon Kerr
Any Carbon Fiber plate chassis should be sanded on the edges and sealed with CA glue. You do this for a couple reasons. One is to keep it from splintering from any impacts. Also, CF is highly conductive. If you allow the ends of your cells to touch raw, un-sealed graphite, it will short out your battery.
#9052
Prototype CAT 4K
#9053
new cat
that looks cool...when will it be avallable? what parts will it share with the mi2? it would be good to have a new 4wd.
#9054
Those are Losi and they have since been replaced by RPM. I like the fit of the RPM ones much better.
#9056
Thanks guys, that's what I wanted to hear... no more slop
For those using the Tamiya shocks, has anyone else switched to the black O-ring, over the clear ones? And do you also find that the "teflon?" washer that extends out of the botton of the shock, where the shaft slides through, tends to open up a bit. After a race day, the oil in the body is still fairly clean, but the shafts are"wet" and atract dirt. Just curious how often, or when you guys put in new seals and o-rings (the "kit" from Tamiya @ Speedtech is under 5 bucks). Thanks
#9060
I got the black ones but my shocks dont leak at all. Thats odd. I will usually get some tire dust on the bottom of the shafts but they are dry.
