Schumacher Corner
#8896
Good luck guys at the snowbirds lets get alot of 1 place finishes.
would like to have the first initial set up and the ending on the first place ride! sence im not there lol
#8897
#8898
Go get em' Team Schumacher at the Snowbirds.
TTT
TTT
#8900
Does anyone know or can anyone tell us if Team Schumacher will be running any new toys or parts at the birds?
Just curious.
Also, hopefully someone will post some starting and ending setups from the birds so we can see what the team is thinking about when running on carpet.
Thanks and good luck to everyone at the big event
Just curious.
#8901
it would be cool to see pics of team schumacher pits at the birds and up close pics of the rides!
#8902
TTT
#8904
Jon Kerr
Any 411 on new go fast goodies?
#8905
Andrew Cartwright
Andrew is 10th after 1st round in Mod.
#8906
Jon Kerr - need a backup car? Check my sig, yo.
Rob
Rob
#8908
hi guys i need some setup help. The back of my car isnt being very co-operative, it swill over rotate when i lift of the gas and over rotates when i am hard on acceleration at corner exit iv tried alot but it still seems to do it. Im driving an mi2 by the way
#8909
John, give us some indication as tou your current set-up. Specifically, tyres/surface, rear shock set-up, roll centre
#8910
im runing
FRONT
blue springs
wishbones forward
1degree camber
o deg toe in
shocjks in outer hole on tower
inner on lower arm
standard roll bar
diff
carbon fiber arms
40wt oil
2hole on piston
5mm ride height
REAR
grey springs
wishbones centre
2 degree camber
3 degree toe in
shocjks in second most outer hole on tower
and2nd inner hole on arm
no roll bar
cf arms
40wt oil
2holle piston
5mm ride height
fron and rear tires are yellow mini pins 20mm
cells back
running 27t on a slippy floor
thats all i can think of that would be of relevance
FRONT
blue springs
wishbones forward
1degree camber
o deg toe in
inner on lower arm
standard roll bar
diff
carbon fiber arms
40wt oil
2hole on piston
5mm ride height
REAR
grey springs
wishbones centre
2 degree camber
3 degree toe in
no roll bar
cf arms
40wt oil
2holle piston
5mm ride height
cells back
