Schumacher Corner
#9646
Originally posted by STLNLST
keep the punches above the belt... See ya in a couple of weeks.
#9647
Hey,
Out of curiousity, Is the Schumacher Mission SST still competative? I might have the opportunity to get one dirt cheap. I'm gonna do some pavement this year (I've been a carpet guy the last year and a half) and am either gonna get a real cheap TC or a new bottom plate for my XRay.
BTW: Is it possible to slap Mi2 suspension on the old car?
#9648
Originally posted by BlackKat
Hey,
Hey,
#9649
Originally posted by cornerspeed
I'm pretty sure the MI2 suspension is not a direct fit to the Mission SST. You can find PW's set-up for the Mission on thier website. That will get that car competitive.
#9650
Hey,
Hey,
Some guys still swear that the SST 99 is still the best Schuie car ever!!
#9651
Originally posted by turbodog
You can slap the Mi2 suspension on the SST provided you have the new upper and lower chassis of the Mi2 along with the Mi2 drivetrain and shock towers!!
Serious it can be done!
#9652
#9653
Not a problem. I'm glad it worked for you. We do use the rear wheelbase adjustment just as you described quite often.
Would you recommend moveing that ballcup in most cases where the care become a tad bit loose or would you go with something else? My car was pushy and it was harder to make corners if I didnt attack them just right so i didnt want to add more rear traction and thus didnt move my ball cups. What would you have recommended in my case.
Thanks,
M.I. JEDI
#9654
Mission1 problem...
Hey guys...I'm working on setting up my Mission for carpet again, and when I have my front shock set up in the outside holes on the arms, I've got a couple of MM of ride height in front, and I've got the shock adjusting collars bottomed... do I need a special lower tower or something or ???
#9655
I still love that car. It was very easy to drive and I made my first A main at the 99 nats with that car....LOL
#9657
Originally posted by AZ_Ron
Anybody have any idea on my above post regarding ride height?
R
R
Short springs require a spring clip
There is a front and rear tower on the Mission, make sure the tower without the 2 small notches is in the front
#9660
R
R
