Schumacher Corner
#8297
That is the kit std front block, and it only has one screw in it. The other block has 2 screws, but the alloy one that replaces it only has 1.
#8299
Originally posted by HarshGuy
Great to see you guys back out again, and you even smelled better than last time we raced together (5 days w/o a shower really "showed" ;-) ) ...STLNLST, what's the website for Brahma, I gotta get me some stock ponies, I'm good with 19T but I just can't seem to find a good stock motor
#8300
Originally posted by Racer X
Got to give props to STL and Mo. Finally dusted off the Mi2 and went racing yesterday and the setup that STL (with help from Mo) hooked the Cop and I up with was awesome! Nothing better than going racing with a dialed setup...of course then all the blame falls on the driver. Thanks as always.
#8302
Originally posted by STLNLST
www.brahmaracingproducts.com If you can't get one before the next time you race just let me know and I'll hook you up. You saw Aaron's car yesterday right???
#8303
Gary there is only one screw in each of the outer blocks the inner ones have 2.
#8306
Now you say that Adrian. Now that I spent an hour whittling out my mounts for the bigger bars I made.
#8307
We also played around with the 17tooth pulley and I think that it give a slight bottom end advantage. Other than that it felt the same. Mo ran a 108 spur and I went with a 105. Using these spurs allowed us to use the same pinions we were using with the 122 and 124 spurs and the 20 tooth pulley.
#8310
Adrain.
Your the best i put eveyone to shame i put to laps on the rest of the field! with your help the other day in 19 t set the track record by almost 2 seconds but i used a oneway and didnt use the breaks at all and it just pulled me around the track i never looked back! except in the main there was this on joker that was onfire he was almost as fast but i just out drove him!!!
thanks alot for your help!
like always!
like always!
