Like Tree2Likes
Losi XXX-S
Old 01-25-2003, 11:07 PM
  #5086
Talking servo saver!!
Originally posted by jjmudd
Is there a servo saver for the XXXs other than the the stock Losi bit? I think the 414 II will work but it is the same style as the Losi.
Just put some CA glue through it and run it..., Ive done that and have'nt had a problem ,,,This was done almost 2 yr's ago and still working.....that's my 2 cent's!!
mb racer is offline
Old 01-25-2003, 11:59 PM
  #5087
Default chassis weight
Hi,
I find that the original xxx-s chassis weight is 200g,
the later graphite chassis is 150g. what about the
G+ chassis ?
anyone attempt to mill to reduce the weight ?
ongbenghui is offline
Old 01-26-2003, 12:06 AM
  #5088
STLNLST's Avatar
Trader Rating: 32 (100%+)
Originally posted by Matt Howard
Stlnlst- correction, I haven't finished a main yet and it wasn't the cars fault. I only ran it the one weekend in stockton and if I remember right I was in the A both races with a car I've never run before that, where were you?
I was being hacked by a schumacher driver....remember
STLNLST is offline
Old 01-26-2003, 12:13 AM
  #5089
Matt Howard's Avatar
Stlnlst- they were only there on saturday, what's the excuse for sunday?
Matt Howard is offline
Old 01-26-2003, 06:36 AM
  #5090
Oasis's Avatar
Trader Rating: 38 (100%+)
Hacked by a YOKOMO!!
Oasis is offline
Old 01-26-2003, 08:41 AM
  #5091
STLNLST's Avatar
It was a TC3 that day.
STLNLST is offline
Old 01-26-2003, 08:45 AM
  #5092
Oasis's Avatar
With a dujan way?You know they cant stop.
Oasis is offline
Old 01-26-2003, 09:04 AM
  #5093
RCTech Member #2
TSR6's Avatar
I got this from Todd Hodge a couple months back:
"XXX-S with no milling done to it 178 grams XXX-S with milling done to it - 150 grams.
-Troy
TSR6 is offline
Old 01-26-2003, 10:14 AM
  #5094
Anyone know the finial drvie for the xxx-s?
teamAE is offline
Old 01-26-2003, 11:13 AM
  #5095
RCTech Member #2
TSR6's Avatar
Final drive ratio = primary (spur/pinion) ratio x drive-train ratio (internal)
The drive train ratio ... or internal ratio is 1.83 using standard diff pullies.
-Troy
TSR6 is offline
Old 01-26-2003, 01:20 PM
  #5096
STLNLST's Avatar
you guys better get use to that word because come the 1st of March he'll really be there.....lol
The guy with the TC3 is a cool dude so it didn't bother me as much as my reactions may have shown. We were both in the Bmain and he was in a zone for that heat. Too bad there were no bump up's.
STLNLST is offline
Old 01-26-2003, 03:57 PM
  #5097
I see. But G+ seems to have more milling done. So, it should
be less than 150 gram.
Old 01-26-2003, 07:24 PM
  #5098
Trader Rating: 19 (100%+)
Anyone have the correct part numbers for the chassis and shock towers for the G-Plus?
DHMOTORSPORTS is offline
Old 01-26-2003, 07:57 PM
  #5099
Super Moderator
Kraig's Avatar
Trader Rating: 81 (100%+)
A-9845 for the rear shock tower and the chassis part number stayed the same, A-9918. We should have the towers in later on this week with a good supply of hub carriers as well.
Kraig is offline
Old 01-26-2003, 10:19 PM
  #5100
JitsuGuy's Avatar
Bearing kits? Can one be bought for the XXX-S? Just trying to get my final list of things I want to get my current XXX-S to the Plus edition. It would be great if Losi sold an upgrade kit.
Thanks,
Jits
JitsuGuy is offline
