Tamiya mini cooper
Only if your purpose was not to have any fun messing with it. Plus, I collect oddball parts.
Something else I'm wondering is if I can get my 03 to handle as cleanly as my 05. From the first time I drove a box stock 05 in 2009, I knew it was a very different car than the 03. Maybe some of that balance will translate.
I'm keeping my M03 in the factory orientation since I only have one.
Get well soon.
I picked up my daughters car at the track today. AS I was fitting her steering servo a man was struggling with the main door, I called out to make sure he was OK and he said he could manage.
a couple of minutes later he came up to me and said his son had given up racing and he'd just laid out a bunch of stuff for people to help themselves to free of charge. He said there was a few mini bits there and I should get in before everyone else does.
so I did.
Scored front and rear alloy hubs, adjustable front end bits, Super CVA dampers, 2 shells (CRX and Alto works) and most of a set of brand new 54000s among other things.
The 54000s have all the external parts and the plastic trees but no metal parts or o rings. Would the bag of bits from the super mini shocks fit?
Whatever the outcome it was a real haul, probably got as much as I paid for Audrey's mini so it feels like a good day.
She drove her car round the track for the first time, slow going but she got round. I've set her car up a bit better now so hopefully we'll get some practice in bashing and get her ready to race.
so I did.
R/C Tech Elite Member
I'm in hospital a lot. That's the joy of a rare, idiopathic, frequently recurrent, disease. No biggy. You'd figure they'd let me have some space to work there, given I spent something like 20% of my time there last year.
For the 3s lipo in a mini......not going to happen. I love to make it better. It's working on the car that's the best part....making it drive netter no matter what the case may be....driveway or racing. It's just the best hobby no matter what.
I installed a 15T brushed motor and a new esc to handle it but now....the forwards (pull trigger) makes it go forwards with reverse power and reverse (push trigger forwards) goes full power in reverse....switched the motor wires when plugging them in and now reverse on the radio (push trigger forward) is forwards full speed on the car when it drives and reverse goes backwards on the car but it's forward (pull trigger) on the radio.
Anyone had this happen before?
Reverse the throttle channel on the radio.
As for the 54000, I think the metal shafts from the super mini CVA's fit (diameter of shaft is same), just double check the lengths and use spacers inside the dampers as needed. I recommend you use the super mini CVA's black pistons inside the 54000's. I run either the 2 or 3 holes with yellow Tamiya oil. The white tiny bore pistons the 54000's come with are imho useless for m-chassis as they are all too stiff even with Tamiya's softest damper oil.
You want a very soft damp setting on these m-chassis borderline almost bouncy for the most part.
I see. Hang in there!!
Yup read the instructions and that's what I haveto do....throttle reverse switch. Never had to do it before so I had no idea.....funny how you read the instructions and everything comes together lol. Pulls nice tho....for the first second or 2 it was moving.
Way too many parts missing from these 45000 dampers to make them work I looked at the part list and it came to about the same money as a complete new set. Might have to invest
Looking at the times for the final last week
http://www.wkrcc.co.uk/current-resul...1_Final_01.htm
I'm nearly 2 seconds slower on my fastest lap than my improvement goal but the spread between best 10 and fastest for me is 0.43 to his 0.97 this gives me hope but also tells me I need to make a drastic change to get faster.
Any thoughts? Start with me doing something different? Start with the car? Bit of both?
The 1 or 2 next to your name is if you are formula 1 (brushless) or 2 (silver can).
I should say the car handles impeccably, very balanced no over or understeer, I'm basically at full throttle the whole time on our big tracks and working on line choices.
I run sweep 25 rear 33 front, I went to 25 at both ends and ended up with less steering for some reason.
You can stiffen the diff a tad more in that case if you're loosing steering from the inner wheel pushing outward (25/25 setting).
At such a big track, they should let you run open class. Run a lower turn motor for some cart wheeling fun.
The diff is a TA03 tightened all the way, should I add shims?
Here is some footage from the meeting before, I didn't drive as well that time, I hit a few things including the new guy who we were lapping every few laps.
https://youtu.be/uaomx82OswA
I think the brushless guys (especially the M rage ones) get the most from the large track. If my daughter thinks she is ready to race next meeting I'll race my GT12 instead so I can help her out.
I love that you get your daughter to the track and get her involved and popsicle racing. It's amazing. How old is she?
any mini racers in the mid-atlantic area might wanna check out this event
http://www.rctech.net/forum/mid-atla...i-madness.html
I ran it the first year and it was awesome, looks like they've tweaked a little over the past 2 years...
Anyone using a shorty pack in their M05 V2? How do you find it?
The m03 is faster than the m05 with the correct electronics/setup/body ,etc....
