Tamiya mini cooper
R/C Tech Elite Member
Y'know, I'm gonna have a shorter life span than most, so perhaps I'll take up cantankerousness (cantankerism, cantankerosity?) now. I've been far too nice to you guys for far too long. Shut yer pie holes, ya bunch of balonies!
How was that? Needs work?
Bob would be proud,
but I think it needs alittle more work!
Or maybe the Candy Stripers in the hospital have already come up with a title for you?
Hey has anyone ever used the tamiya slick tire? They don't seem to badly priced on ebay....5 a tire delivered almost
..I'll give em a try I think?
Ya I'm going to run them on the front and see what happens.
Do you guys remember the question about lowering the front control arm in the front to the lower of the 2 holes for more camber? I did it and now it looks like way more toe in than toe out. Not sure how it drives yet but it doesn't look like it will be good considering these lil guys like the toe out. Any of the veterans here tried this?
And Jim....your doing just fine in your cantankerousness lol
Love all the guys in this forum!!! Wouldn't it be nice if we could all meet for a race? I'd gladly bring up the back just for the experience!!
Type A front, S-grip rear worked great for me on high-traction carpet, and one of our other guys here has successfully used that same combo on asphalt.
I know...it adjusted as much as it will go for toe out....I may be new but that's just rediculous lol.
I'm going to try changing the holes around on the front uprights. Totally forgot about there being 3 holes for the king pins to be in. See if that helps
I've tried something a little different with my diff. I've used 1/8in ceramic balls instead of the 3mm spec ones. Also built with a little associated grease and sanded the diff plates. It had a decent action, I could get it quite a bit tighter as well. Figured the .175mm difference was just like putting in a .2mm shim.
Keep in mind though that there are so many combinations to build your Tamiya Mini that what works for me may not for you... as there may be a ton of other things that are different about each of our setups. ...But I do like this tire combo a lot. (a lot of guys at our track I notice started running this style as well ...I think I was the trend setter).
That may be me that your referring to?? I've been using A-slicks up front and S-grips in the back for the past 2 seasons on medium level grip asphalt. I love this combo ...really works best for me (i've tried every combo of TCS legit wheels/tires)... (a lot of guys at our track I notice started running this style as well ...I think I was the trend setter).
Can I take some of the credit?
We're all still young on the inside!
http://www3.towerhobbies.com/cgi-bin...?&I=LXCBCZ&P=7
What???!!!!
Has this body been discontinued??? I love this body, its all I use and will ever use.
So if its discontinued does that mean it won't be allowed by TCS?
Should I go out and buy all the JCW bodies I can find?
Is the sky falling? What will I do. Its taken' me years to find the perfect body and now they go and discontinue it!!!
What???!!!!
Ya the toe I don't think was in too much. It handled pretty damn well with the arm drop in the front. I have slick type B tires and super slicks coming in the mail. I'm gonna try that combo for now. Got the super slicks at 5 a tire. See how that works. Found a nice concrete patch to drive at the park too. Little loose but enough space to run off with no obstacles to break stuff tho. Going to get some markers and make a course.
