Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 01-13-2014, 06:24 AM
  #20176
Originally Posted by CraigMBA
What is the TCS rule re fan mounting? Can you just bond them on the chassis, or is it like the heat sink and you have to bolt it to the motor?
Not to post multiple replies, but what are the TCS Legal parts for A front foam bumper for the m03 or m05 chassis? Can you get the block of bumper foam for a sedan (a tamiya part), cut a chunk out, and just bond it in?
Most of the locals just glue the fans for the M03. The M05 requires a bracket of some sort. Except for an endbell mount, there really is not a way to mount it to the motor like they do in a TC. The endbell mounts exposed the fans to damage.
Bonding foam to the body has passed tech in the past. I've been using the M06 foam bumper and silicone glueing it to the body
Granpa is offline
Old 01-13-2014, 09:00 AM
  #20177
fresnojay's Avatar
Carlton, did you have an issue with one of the minis overheating Saturday? Or Judy worried about the future runs?
Jason
fresnojay is offline
Old 01-13-2014, 09:30 AM
  #20178
CraigMBA's Avatar
Trader Rating: 22 (100%+)
Jason
No problems on Saturday, but the Rent-A-Racer is currently brushed.
My biggest concern is the M03R I have that I built. I weighed it - ready to run (no fan), And I knew it would be light. What I wasn't expecting was I need to add something in the neighborhood of 200 (two hundred) grams to get it to legal weight.
TCS rules allow up two fans, so there's some weight I can add.
Thanks Grampa!
CraigMBA is offline
Old 01-13-2014, 10:16 AM
  #20179
KA2AEV's Avatar
Anyone know what the new mini tcs weight is?
KA2AEV is offline
Old 01-13-2014, 10:23 AM
  #20180
whitrzac's Avatar
Trader Rating: 97 (100%+)
All M-chassis cars must meet a minimum weight of 1250 grams.
whitrzac is offline
Old 01-13-2014, 11:11 AM
  #20181
Trader Rating: 28 (100%+)
Exclamation
Originally Posted by whitrzac
The Tamiya USA web site shows 1250 per the following link:
http://www.tamiyausa.com/tcs/tcs.php?article-id=531
That said, the 2014 Regional TCS .pdf that was released shows the weight minimum at 1300g
http://www.rctech.net/forum/electric...s-rules-v2.pdf
Confirmed with FMW - 1300g is correct
madjack is offline
Old 01-13-2014, 11:23 AM
  #20182
R/C Tech Elite Member
monkeyracing's Avatar
You built an M03 that weighed 1000 grams, battery in, body on, ready to go? I'm impressed. I haven't been able to get one quite that light. All Plastic? Really small battery? Curious to know.
monkeyracing is offline
Old 01-13-2014, 12:27 PM
  #20183
KA2AEV's Avatar
Thanks Jack.
KA2AEV is offline
Old 01-13-2014, 02:38 PM
  #20184
CraigMBA's Avatar
About 200, not 300!
1120 grams less transponder. AL uprights, shocks, mini receiver, AL driveshafts, Novak speed control. Aluminum screws anywhere it's not load bearing, 4200 mha PEAK battery.
Here's a pic (i know, it's 1146g, I added 26g of tungsten before I had to stop because I ran out, and I'm not taking it out for the photo). Only 160 grams left to go!
CraigMBA is offline
Old 01-13-2014, 04:40 PM
  #20185
fresnojay's Avatar
I had to add a round 60g to my mini in order pass tech Saturday. Was surprised as the last time I weighed it I could have sworn it was right at the old spec of 1280g. Mind you I am still brushed at this point too.
Jason
Old 01-13-2014, 04:43 PM
  #20186
CraigMBA's Avatar
I'm pretty sure Rob had his less than 1000 the first round with that 2s receiver pack he was running....
CraigMBA is offline
Old 01-13-2014, 05:40 PM
  #20187
fresnojay's Avatar
Lol. That wouldn't have surprised me in the least. I knew he had the pack in there like that and we both had a good laugh when he told me. I wasn't worried about anyone's tech other than mine because I always get tech'ed because I get called a cheater a lot. I welcome anyone to do a full tear down if they so wish to prove them wrong. I was just elated to have more minis running.
Jason
Old 01-13-2014, 08:01 PM
  #20188
CraigMBA's Avatar
Rob got two and a half from Dustin, so he and Maria will be rolling here shortly. Daniel has a M05 now, he texted me at the track and told me he'd be out by the end of the month. And I have the Rent-A-Racer, the massively underweight M03r, and two M05s still in a box. Somebody asked me what class a new racer should run, I told him Mini or VTA. The class is growing.
I think I need a Tamiya intervention.
CraigMBA is offline
Old 01-15-2014, 09:52 AM
  #20189
silverbmr's Avatar
Is it necessary to put weights at the front of a m05 chassis for better grip on the front wheels? if yes, how much weight?
silverbmr is offline
Old 01-15-2014, 11:03 AM
  #20190
howardcano's Avatar
Trader Rating: 37 (100%+)
I haven't added weights per se, but I am running a huge homebrew front bumper that brought my car up to the minimum weight for our track (1250g).
I also changed my car over to the long wheelbase to try to get more forward traction, but it hasn't proven to be a big advantage versus the medium wheelbase.
howardcano is offline
