Tamiya TB Evolution V >
Like Tree143Likes
Old 04-17-2007, 10:50 AM
  #1171
Originally Posted by TryHard
Just do the front diff trick then... they allow a diff dont they If you really want to get it tight, cut out some sandpaper to the same size of the diff rings, and replace the balls with then.
The Losi uses a similar trick, replacing the balls with a hard plastic pad.
HiH
Ed
sandpaper, that sounds like the best and easy to do option
DrKucho is offline
Old 04-17-2007, 10:56 AM
  #1172
HiH
Ed
sandpaper wouldn't seem to be a problem on a belt car, but it would seem sandpaper on an enclosed gear diff would get sand in the teeth of the gears
DOTMAN is offline
Old 04-17-2007, 11:14 AM
  #1173
TryHard's Avatar
Seriously, I doubt it. The sandpaper isn't ment to move (it's a spool after all), just grip the plate. The "sand" would only fall off is due to a sanding action...
Hence it's very unlikely any sand would cause a problem. Use a high grit #, and really wouldn't be a problem.
HiH
Ed
TryHard is offline
Old 04-17-2007, 03:02 PM
  #1174
OleC's Avatar
I cant see why you should have problems with the EVO IV spool?!? I've used it with the TA05 steel outdrives for almost a year now. No mods. Fits perfect! :-)
OleC is offline
Old 04-17-2007, 03:49 PM
  #1175
With no modifications?
DOTMAN is offline
Old 04-17-2007, 03:50 PM
  #1176
TryHard's Avatar
Honestly, I have the same issue as infokiz, it just won't fit in the bulkhead, as the distance between the bearings is different, and I couldn't get the meshing right.
Seems like some get ones that fit no issues, and other have this problem... not a clue why
TryHard is offline
Old 04-18-2007, 03:11 PM
  #1177
OleC's Avatar
No mods. Fits like a glove...
I use a couple of .1mm shims to take up play, but thats it.
I can check agin with the part number, but I'm sure its the EVO IV spool from tamiya.
OleC is offline
Old 04-18-2007, 03:21 PM
  #1178
Thx, OleC. Well from what you and TryHard are saying, looks like I should just test fit mine to see if it works. Sounds llike it's a hit or miss kind of thing
DOTMAN is offline
Old 04-19-2007, 01:17 AM
  #1179
veecee's Avatar
Trader Rating: 34 (100%+)
Pls post a photo if you can.
veecee is offline
Old 04-19-2007, 03:05 AM
  #1180
TryHard's Avatar
hmm, I think I might have an answer to this...
You mention you are using the TA05 steel outdrives. I've had a quick look at some pictures (unfortuantly I don't have any to hand atm, so don't know if this is fully correct), and it would appear that the flange to hold the bearing in place is thinner on steel cup, than on the standard Evo4 black plastic cup. This would mean the bearings could be placed closer together, enabling a drop in fit...
Do you still have the plastic outdrives? any chance you could confirm if this is the case?
Cheers
Ed
TryHard is offline
Old 04-19-2007, 02:47 PM
  #1181
Hebiki's Avatar
Trader Rating: 26 (100%+)
Cheers
Ed
are the black plastic ones have the same thickness sleeve as the white delrin that comes with MRE spool? cus i can double check those.
makes sense though to run the TA05 spool drive cups since they are steel and would hold up better.
Hebiki is offline
Old 04-20-2007, 12:54 AM
  #1182
TryHard's Avatar
Not sure about the spacing on the drive cups, worth checking the MRE ones though
BTW, my Evo5 is still for sale;
http://www.rctech.net/forum/showpost...postcount=1156
Offers welcome (I haven't got round to putting it on flebay yet, will do so next week).
Regards
Ed
TryHard is offline
Old 04-20-2007, 03:30 PM
  #1183
surrealmaterial's Avatar
quick question, is the servo arm included in the kit a servo saver? If so how does it work?
Cheers
surrealmaterial is offline
Old 04-20-2007, 03:32 PM
  #1184
Cheers
yes it is , it has C shaped springs inside
DrKucho is offline
Old 04-20-2007, 03:42 PM
  #1185
cheers
