Tamiya TB Evolution V >
Like Tree143Likes
Old 04-28-2007, 03:48 AM
  #1201
waOscar's Avatar
Originally Posted by oscarin2000f
Hola Drkucho.
The question is for an EVO IV, sorry.
I have posted it here because i canīt find the oficial post of evo IV.
Thank you.
EvoIV thread
http://www.rctech.net/forum/showthre...29#post2952129
And EvoIV uses EvoIII diff outdrives. TB02, TB02R, TB EvoIII and TB EvoIV all use the same diff outdrive.
waOscar is offline
Old 04-28-2007, 11:18 PM
  #1202
surrealmaterial's Avatar
today i rebuild my rear diff and i noticed 2 of the balls were missing.....does this matter?
surrealmaterial is offline
Old 04-30-2007, 01:23 AM
  #1203
also can anyone confirm that these fit on the evo 5?
http://www.rcmart.com/catalog/produc...ducts_id=23390
Old 04-30-2007, 03:45 AM
  #1204
TryHard's Avatar
Yup, they'll fit.
As for your diff question, it won't help. You'll probably find the pressure in the diff changes during it's rotation with balls missing.
HiH
Ed
TryHard is offline
Old 04-30-2007, 03:50 AM
  #1205
ok thanks, and i also noticed when i brake my car makes a weird crunching noise.....(im running a front oneway)
Old 04-30-2007, 05:02 AM
  #1206
TryHard's Avatar
check your bevel gear spacing... sounds like you are skipping teeth under braking.
HiH
Ed
TryHard is offline
Old 04-30-2007, 02:05 PM
  #1207
ive checked them, there all fine, do you think its got something to do with my diff? because the brakes only apply to the rear wheels when running a front oneway
Old 05-01-2007, 12:48 AM
  #1208
another quick question, is Tamiya Anti-Wear grease any good for the bevel/oneway/diff gears?
Cheers
Old 05-01-2007, 02:15 AM
  #1209
TryHard's Avatar
Cheers
I understand the best stuff to use is the white ceramic greese. Personally, I wanted to try McLube (a dry teflon spray-on lubricant, used on boats), but never got round to it.
With regard to the gear slipping... could be a diff issue, rebuild it and see what happens.
HiH
Ed
TryHard is offline
Old 05-04-2007, 05:51 PM
  #1210
hey guys,
i got another problem with my diff , when i was driving it lasted for about 1 minute, then when i brake the car would just roll freely, and i was only running FWD. I figured out the screw holding the diff together came loose, but if i tighten it, it would work for a minute or so then just does the same thing over and over.........any solutions?
Cheers
Old 05-05-2007, 03:36 AM
  #1211
TryHard's Avatar
hey guys,
Cheers
Check your diff lock nut, could be that it's old and worn, and needs replacing.
Regards
Ed
TryHard is offline
Old 05-05-2007, 03:40 AM
  #1212
alright thanks, ill give it a try
Old 05-05-2007, 11:03 PM
  #1213
is the standard evo 5 setup any good on asphalt/smooth concrete?
Cheers
Old 05-06-2007, 07:46 AM
  #1214
TryHard's Avatar
New price on my evo guys... $300 all in + Shipping. see link in sig.
Ed
TryHard is offline
Old 05-06-2007, 07:40 PM
  #1215
tamiyarcracer's Avatar
Cheers
Try it out and let us all know.
tamiyarcracer is offline
