Team Associated B6 & B6D thread
#5836
But one thing I've been doing since I got in this hobby... I reasearch the issues I'm having and change things up little by little.. trying to keep note of what all it did .. I've moved things around just so I personally know through experience what it does, not just cause I read it somewhere...
#5838
Trader Rating: 89 (100%+)
changes and tires
I ran 12 heat races making 1 change each race to get to the set I am at now.
I clean and fully sauce all four tires after each race .
#5840
We often forget that 1/10 scale cars regularly reach speeds far in excess than their full-scale counterparts. Even a stock buggy for example, can reach speeds of nearly 20-30mph down a back stretch.
I can't imagine driving a full scale off-road vehicle 200-300mph on a dirt road...
Small changes are magnified.
#5841
The affects are even greater...
So much Yes! couldn't agree any more with your statement
#5842
How are you guys mounting a fan with a standup WITHOUT a waterfall mount?
#5844
Moving the shocks to the front of the tower takes away rear bite, it has the same effect on any laydown car you can get YZ-2, B6, etc. The brass C plate puts the weight where you want it, but is not a definite fix. Depending on how loose the track is, you may never get the rear bite you want without adding weight somewhere. The AE manual is 100% right, shocks in fronmt allow for better steering coming out of the corners and a tighter turning radius, shocks in the rear provide more traction at a minimal loss of corner speed steering. Your tires, and track conditions will dicatate what works for you, and what wont. If you look on the Kyosho forum (car I had before I went to AE) a large number of drivers have gone back to 4 gear laydown transmissions with the shocks in front since the motor is turning the opposite way, the rear squats more, and adds grip withjout losing corner speed steering. I wonder if AE is looking into adding this option? would (in my opinion) help with laydown on lesser then high bite tracks.
#5845
Of course, I realize the only real way to find out what works for me at my track is to make these changes one by one and then try it out. But I can't get back to the track until next Saturday, so I figure hyper-obsessing here is the next best thing hehe.
#5846
Searched the entire thread, can't find what inserts to use for aluminum D mount..?
#5848
Okay guys, my Google-fu isn't too sharp tonight. Just got back from a day of carpet racing, 17.5 class. Managed to break every round, which was a first. First breakage was the MIP rollers gear diff outdrive. So I took the transmission apart and put the stock outdrives and dogbones back in. After that, I'd get a lap or 2 in the race and the dogbones would pop out. I noticed that the bones were only hittin the outer edge of the outdrive. So, once I verify I didn't leave out any shims or spavers, can one of you fine folks point me to the longer dog bones? Thanks in advance
#5849
#5850
Makes sense. So this is needed if you use the aluminum D block? I wonder why it didn't mess me up when I was using the MIP drives and roller set up. I'll get these on order along with a few other goodies. Thanks again!
