Castle Creations Mamba/MM/MMM FACTORY Q&A thread!
#451
you cannot use a 4S lipo because it is past the max voltage on the esc...
#452
i was wondering if the 7700 motor could take 2s2p li-ion batteries? they are only rated at 6.6V but i wanted to check before i go and buy a $100 battery. thanks
#454
not the ones im lookign at. they have a 30C constant and a 70C burst for like 1 minute at a time. ive seen people use them with 5700 and they rocket. a ton faster than a 7.2V nimh
#455
Why not look for a 3S (3 cell) lipo and grab a 5700 if you're after speed...
#456
price is a limit. also space. my buggy is a dark impact and it is tight for a 6 cell nimh. i dont think a 3s would fit. plus charge time. the a123 system will fully charge a 4600 battery in 20 minutes and it makes the power and run times of a 4200 8 cell nimh
#458
If its a tight fit for a 6 cell nimh, then ull have trouble fitting the a123 4600 cause its a bit fatter...
#459
Location: Filipino Contract Worker in Khobar, Saudi Arabia
Bearings
Originally Posted by CRASH
The Mamba Max motors are sealed and are not serviceable. If you are having a bearing problem please contact Joe to try and remedy this problem. But you should not be having any sort of bearing problem.
913-390-6939 Ext 119
Later,
Later,
#460
no a123 are li-ion. and i have a little bit of space. enough to fit the width. but thickness is a problem. these batteries should just fit.
#461
Originally Posted by rc_speed
I talked to castle creations tech support this morning.
They said that I should us the 5700 motor and then run a 3S lipo. My current lipos are too small. I need at least a 4000 or even bigger to handle the amp draw. They said that for the large track I run on, to gear the car as high as it would go. then reduce the gearing if the motor temp exceeds 200. He said I should be able to get 60-70mph out of this car and runtimes will vary buy I may get anywhere between 7-15 or more minutes.
Now I have to figure out how many battery packs I need.
thanks,
tim
thanks,
tim
and what ppl are saying here is to wire the motor with no plugs and short
and run the capacitor on the receiver.
i want to run the 5700kv in a kyosho 4wd.
#463
Originally Posted by wallyedmonds
so what you are saying is to get 4800 lipo pack.
Im waiting for a orion 3200 LiPo, a novak glitch buster capacitor, & a new 4600kv motor that will be hard wired, ill let you know how they all go together in one...
#464
I just wanted to say thanks to Castle for a quick warranty repair to get my 2nd Mamba Max system back on the track. Although I have to cut the bullets off again and put my deans back on, I couldn't be happier with the repair service.
I pulled out a nice A-Main win in 4wd buggy yesterday with a MM5700 system with a MaxAmps 8k LiPo XXX-4 besting a Permax(?)/ThunderPower system, a MM4600 system on MaxAmps 3s 6k and some brushed motors.
My MM4600 powered 4-cell NasTruck was also making a very strong showing until a turnmarshall put me down in front of a full speed pack of cars coming out of a turn low in the 2nd qual round and absolutey creamed my truck and took me out for the rest of the day.
I get more questions on what motors I'm running than any other setup I've run in the past.
Thanks guys!!!
Thanks guys!!!
#465
can not get my esc to arm to my radio. Did everything in the book it says to do and nothing. i hold full throttle and soon as i hit the switch it beeps and goes red then i full break and get beeping again and green light, then go nuetral and all the lights light up and then it beeps and goes red for a while then it turns yellow and beep continously and thats all it does. I dont know what else to do. Anyone?
