Go Back  R/C Tech Forums > International Forums > Singapore R/C Racers
Newbies Queries - Ask and you shall be answered! >
Like Tree1Likes
Old 06-20-2003 | 02:57 AM
renben's Avatar
Default Newbies Queries - Ask and you shall be answered!
Just thought it would be good if we have a thread where we can ask all the newbie questions or any questions that the pros here can answer.....
lemme start, would buying a new stock motor improve the speed of my touring car? (my old motor is nearly 6 years old ... but only has got like 10 runs in it.... still can work)
renben is offline
Old 06-20-2003 | 07:40 AM
NightKidZ's Avatar
Yes, a new motor will be faster than the old one.
Why?
Because the magnet demagnetises itself over time, more so if overheated.
Cheers
NightKidZ is offline
Old 06-20-2003 | 07:46 AM
Default e-clip question
Hi,
I heard of a veteran who told me to get from hardware store but till now I cannot get any from the stores I went?
Does anybody knows if I can get 2mm e-clips and 3 mm e-clips from hardware stores? Which hardware store to recommend?
Thanks in advance
brumbar is offline
Old 06-20-2003 | 10:41 PM
Bugs Bunny's Avatar
Default Re: e-clip question
Originally posted by brumbar
Hi,
Thanks in advance
You can try going to Kelantan Lane which is near to Sim Lim tower, where you can see a lot of selling old stuff stall. There are a lot of hardware store over there. You can try your luck there.
Bugs Bunny is offline
Old 06-21-2003 | 01:34 AM
hellangel's Avatar
Default Re: Re: e-clip question
yes... u will most definitely find e clips there... remember to bring a sample of wat u want to buy... helps to save u from making a wasted trip...
hellangel is offline
Old 06-21-2003 | 11:47 PM
segaff's Avatar
Registered User
i got a question
I bought a new Nova engine. The settings are factory. When i planted it into my superten, the tyres wont stop moving even when the idle i set was the lowest as well as the high n low end needles. The speed of the tyres were like 1/16 throttle. Moves quite fast on the ground.
segaff is offline
Old 06-22-2003 | 01:10 AM
NomeXX's Avatar
From: Indonesia sometimes, Singapore sometimes, Mars sometimes, Venus sometimes...but home is where I wanna be
Originally posted by segaff
i got a question
Check List --->
1. Idle screw
2. Low end mixture
3. Clutch/ clutch spring
4. Throttle linkage/position (remove your airfilter, check throttle position at neutral)
5. Air leak in fuel line/cylinder head
....that's all I can think of now
NomeXX is offline
Old 06-22-2003 | 03:01 AM
Hi,
i have a quite new RS4 SS
problem:it isnt shifting..it used to shift on earlier runs.
i have tried different shift points but no avail.
anyone got ideas?please help , thanks.
Ding82 is offline
Old 06-22-2003 | 09:58 PM
WC's Avatar
WC
Originally posted by Ding82
Hi,
Check your manual and reset the setting back to "stock".
Usual error is the 2spd changes too early rather than too late. Some ppl don't realise their car is already/always running on 2nd gear when they think it doesn't get out of 1st gear.
Usually with HPI's 2spd gearboxes, the stock top gear is same ratio as a 1spd car with their biggest clutchbell pinion. The top speed of both cars will thus be the same.
WC is offline
Old 06-23-2003 | 12:18 AM
hellangel's Avatar
Default Question on Silly Putty
i read in a mag dat u can stuff the gearbox wif silly putty to stiffen the diff action for bevel type gear diffs...
but i am not too sure wat is silly putty... is it avaliable locally?? is it the same thing as playdoh??
Old 06-23-2003 | 12:35 AM
renben's Avatar
I also dun know what silly putty is...... but i suppose its some removable clay tat u can use to lock the gear diffs.....similar to tightening the ball diffs..... locking the diffs is supposed to give you more power out of the turns...... i think....
renben is offline
Old 06-23-2003 | 12:47 AM
hellangel's Avatar
i know wat stiffening the diff action does to the car... wat i want to know is wat is silly putty... or if there is anything on the market dat has the same kind viscosity as silly putty...
Old 06-23-2003 | 01:03 AM
alana07's Avatar
Originally posted by hellangel
yes... i know wat stiffening the diff action does to the car... wat i want to know is wat is silly putty... or if there is anything on the market dat has the same kind viscosity as silly putty...
silly putty is serpent's grey cleaning clay/putty/whateverucallit!!! yes, i read in mytsn before, some of the fuctory snake drivers used that in the impulse's rear diff case.
alana07 is offline
Old 06-23-2003 | 01:21 AM
hellangel's Avatar
ok... thanx...
Old 06-23-2003 | 02:50 AM
Default Screws, hardware etc
Just to add, Kelantan Lane got a screw shop that is pretty friendly. And they sell US type 4-40 screws as well.
So, if you need screws and fastener, check out that place. I am sure, it is cheaper than more hobby shop.
ongbenghui is offline
