Xray T1
#7457
Sorry i should have specified where my problem lies...
The part I am concerned about is the one where the hingpin can slide right through... in this kit i believe all the holders should only have a hole on one end for the hingpin.... in my case... i have 3 that only have a hole on one side... and 1 of them has a hole right through it....
Regards,
Regards,
#7458
Originally posted by theisgroup
the T1fk will not accomodate the pillow ball suspension. This is because the bulkheads have been lightened and do not have the mounting holes for the PB suspension.
GUYS: need some help, i'll try running my FOC with the short arm conversion tom, can u give me an idea what droop i should use (f/R)? should i use the recommended droop settings for the FOC c-hub or the FK? tanx.
#7459
I recently bought a used T1R and I am thinking of converting it to the short A-arms. What stuff (except for the arms...) do I need to do this ??
#7461
Re: factory kit bulkheads
Nobody wants these things. A couple of weeks ago people were looking for them...I have them...brand new never used.
Originally posted by Joneser
Guys...I have a set of brand new unused factory kit bulkheads that a deal fell through on. 95.00 shipped anywhere in the USA.
#7462
XRAY T1 FACTORY KIT?
Hey guys,
I'm about to order a T1 Factory Kit and I just need to know what else should I get for it, what doesn't it come with?
Example: Anti-Roll Bar Set?
Thanks guys for your time..
#7463
extra diff and spring set and thats about it
lazyboy
lazyboy
#7464
Re: XRAY T1 FACTORY KIT?
Originally posted by Vegetto
Hey guys,
Hey guys,
It just comes with a front one way so I think that you should buy a regular diff for the front in case you dont want to always run a one way..
#7465
Hey guys,
Hey guys,
the settings that was recommended by the manual kinda made my car spinout so i downloaded the cyruls set-up for the reedy race held last month. www.cefx.net the car was totally hooked up!!!
#7466
Thanks guys!!
Does anyone have a good indoor carpet setup?
I'm running Mod, the track is small and twisty...
Thanks guys
Thanks guys
#7467
I run a factory team indoors on carpet with rubber tyres -
Front
Dark blue springs with 30wt oil 2 holes open. Shocks mounted in the middle hole at the top.
Middle roll centre position on bulkhead, standard castor 1deg camber 0deg toe in.
Rear
Light blue springs with 30wt oil 2 holes open. Shocks mounted in the middle position at the top and outer hole at the bottom.
Middle roll centre position on bulkhead, 2deg camber, 2 deg toe in.
I run a one way pulley at the front and a loose rear diff (the diff is set properly but as loose as it will go without slipping), so the car is a little more forgiving in the low speed tight turns or if the grip is very low.
I run pits D20 wets because we have to run treaded tyres at the club i race at. I run my cells at the back next to each other.
Hope this helps, my car carries huge amounts of corner speed!
Front
Rear
#7468
shocks
cant remember how many times this has been covered but is anyone running different shocks on their T1R or FK. I am looking at tamiya or HPI shocks. I need something with aluminum bodies and I am not sure about x-ray aluminum. thanks.
#7469
Re: shocks
Coney
