Old 06-17-2004, 08:43 PM   #7456
It is the correct part. Look close in the instructions. One is plastic.
XrayEye is offline   Reply With Quote
Old 06-17-2004, 08:55 PM   #7457
Trader Rating: 18 (100%+)
Sorry i should have specified where my problem lies...
The part I am concerned about is the one where the hingpin can slide right through... in this kit i believe all the holders should only have a hole on one end for the hingpin.... in my case... i have 3 that only have a hole on one side... and 1 of them has a hole right through it....
Regards,
Wayne Mah
Sponsors: Avid Racing -- ORCA -- Awesomatix -- Pro-line -- Protoform
SkaterX is offline   Reply With Quote
Old 06-18-2004, 03:22 AM   #7458
evaa's Avatar
Originally posted by theisgroup
the T1fk will not accomodate the pillow ball suspension. This is because the bulkheads have been lightened and do not have the mounting holes for the PB suspension.
i beleive this is true only with the front bulkheads as the rear bulkheads do not require the upper a-arms.
GUYS: need some help, i'll try running my FOC with the short arm conversion tom, can u give me an idea what droop i should use (f/R)? should i use the recommended droop settings for the FOC c-hub or the FK? tanx.
evaa is offline   Reply With Quote
Old 06-18-2004, 03:53 AM   #7459
Manfredo's Avatar
I recently bought a used T1R and I am thinking of converting it to the short A-arms. What stuff (except for the arms...) do I need to do this ??
Manfredo is offline   Reply With Quote
Old 06-18-2004, 09:36 AM   #7460
Scrad's Avatar
Trader Rating: 15 (100%+)
I found that the T1R chassis doesn't work that well with the short arms. The droop screws sit too far out on the chassis and flexes too much. So the droop is changing. You'll have to use internal shock limiters.
Scrad is offline   Reply With Quote
Old 06-18-2004, 11:55 PM   #7461
Default Re: factory kit bulkheads
Nobody wants these things. A couple of weeks ago people were looking for them...I have them...brand new never used.
Originally posted by Joneser
Guys...I have a set of brand new unused factory kit bulkheads that a deal fell through on. 95.00 shipped anywhere in the USA.
Joneser is offline   Reply With Quote
Old 06-19-2004, 07:44 PM   #7462
Vegetto's Avatar
Default XRAY T1 FACTORY KIT?
Hey guys,
I'm about to order a T1 Factory Kit and I just need to know what else should I get for it, what doesn't it come with?
Example: Anti-Roll Bar Set?
Thanks guys for your time..
Vegetto is offline   Reply With Quote
Old 06-19-2004, 07:46 PM   #7463
lazyboy's Avatar
Send a message via AIM to lazyboy
extra diff and spring set and thats about it
lazyboy
Random Guy
FT B4
Sponsored by Axiom Motors
Trackside hobbies
lazyboy is offline   Reply With Quote
Old 06-19-2004, 07:56 PM   #7464
RCchica's Avatar
Send a message via AIM to RCchica
Default Re: XRAY T1 FACTORY KIT?
Originally posted by Vegetto
Hey guys,
It just comes with a front one way so I think that you should buy a regular diff for the front in case you dont want to always run a one way..
RCchica is offline   Reply With Quote
Old 06-19-2004, 07:57 PM   #7465
S-T-R-l-K-E-R's Avatar
Send a message via ICQ to S-T-R-l-K-E-R
Hey guys,
yo veggie - i got a FK and it rocks!!!! i was able to keep up with the mod guys using a 19t in our track!!! all i bought was a front swaybar thats all. i have been running it for about 2 weeks now and thank god i havent broken a single thing =)
the settings that was recommended by the manual kinda made my car spinout so i downloaded the cyruls set-up for the reedy race held last month. www.cefx.net the car was totally hooked up!!!
S-T-R-l-K-E-R is offline   Reply With Quote
Old 06-20-2004, 01:30 AM   #7466
Vegetto's Avatar
Thanks guys!!
Does anyone have a good indoor carpet setup?
I'm running Mod, the track is small and twisty...
Thanks guys
Old 06-20-2004, 07:52 AM   #7467
Robfo's Avatar
I run a factory team indoors on carpet with rubber tyres -
Front
Dark blue springs with 30wt oil 2 holes open. Shocks mounted in the middle hole at the top.
Middle roll centre position on bulkhead, standard castor 1deg camber 0deg toe in.
Rear
Light blue springs with 30wt oil 2 holes open. Shocks mounted in the middle position at the top and outer hole at the bottom.
Middle roll centre position on bulkhead, 2deg camber, 2 deg toe in.
I run a one way pulley at the front and a loose rear diff (the diff is set properly but as loose as it will go without slipping), so the car is a little more forgiving in the low speed tight turns or if the grip is very low.
I run pits D20 wets because we have to run treaded tyres at the club i race at. I run my cells at the back next to each other.
Hope this helps, my car carries huge amounts of corner speed!
Robfo is offline   Reply With Quote
Old 06-20-2004, 09:36 AM   #7468
scmicromike's Avatar
Send a message via AIM to scmicromike
Default shocks
cant remember how many times this has been covered but is anyone running different shocks on their T1R or FK. I am looking at tamiya or HPI shocks. I need something with aluminum bodies and I am not sure about x-ray aluminum. thanks.
scmicromike is offline   Reply With Quote
Old 06-20-2004, 09:56 AM   #7469
Coney's Avatar
Send a message via ICQ to Coney
Default Re: shocks
Why, isnt the Xray Alu Shock Bodies any good?
Coney
Coney is offline   Reply With Quote
Old 06-20-2004, 12:36 PM   #7470
rayhuang's Avatar
Default Re: Re: shocks
Coney
Coney,
The aluminum shocks are good-but the plastic are smoother. Even the Team Serpent gas drivers only use the aluminum shock in HOT weather.
