Tekin RS ESC sensored
Hey Randy, thanks for helping!! OK, esc set to 1S lipo voltage-cutoff set for 1S... I then re-bind the receiver, turn off the esc, removed the bind plug and connected the booster (bat/bind port), , set the radio to 100% brake and throttle settings ... turned esc on again, re-calibrated the esc, turn off/on again, arming sequence starts with no sounds and then finishes on the middle led (NW) solid for 3 seconds then flashes to the first led (DB) then immediately returns back to the middle led (NW) solid again for 3sec and ecs repeats this process.
Also, with the above process completed on a 1S Lipo (tried two different batteries, full charge)... I have steering NO motor.
I then tried turnning off the esc unplugged the 1S and connected a 2S (with all the same setting as above and removed the booster), funny thing the sounds chime esc arms itself and power to everything. Motor spools up and all works fine!
Could it be a bad booster!?
Randy is 100% right, i had EXACT same thing happen with mine, after close inspection found with my tq booster, the red wire came undone on the esc,so it looked as if everything was sorta working, but the lower voltage wouldnt let me get power/chime etc...dont know what booster ur running, but with my tq, i have the leave the esc switch ON and than the booster ON, but i hear novak esc off, etc...check to be sure u have right combo...definatlly booster
well my RS Pro is in THE post
should be with me on Friday
what is the first thing i need to do ?? is there an update for it now or will it come with the new one in it ??
sorry for the noob Questions but i am coming from the LRP stock spec with simple buttons to set up
yup, thats what it was... faulty booster, it was obvious after connecting the transponder on 1S and the light was barely visible, just tried another booster and it works fine now! THANKS GUYS!!
#1 Buy a Hotwire,
#2 Get update via Tekin website, 4.0 will say vegas and such
#3 Put on a helmet,cause this aint lrp anymore!!!
#4 Remove Lrp from ur signature,set Tekin in it's place..
Have fun
Have fun
What should we be using as a basis for the rpm range to boost the timing? I know what has been posted but its doesn't seem to have any science behind it. I have a Novak sentry system so I can see what my RPMs actually are at different points on the track. With a 17.5 motor I get over 20K at the end straightaway and down to 4K or so on a slow corner.
there is one ordered
is this free to update ???
no i have been trying to keep up for a couple of weeks waiting for it to clear customs in NL
not just yet , it hasn't arrived yet
i intend too , 15.400 lap times ere i come LOL
Fantastic!!!!..yes it is free to download, just register,click,its in ur mailbox..
i got to run my rs for the first time last night.
but the throttle felt a little funny, it felt flat from low to mid. is there an adjustment for that? i was running throttle profile 3
To get really scientific about it, you would really need dyno data for the motor and speed control combined to really fine tune it. Without that, track testing will have to suffice.
Did it feel like a lot of negative exponential on the throttle or was the motor just flat coming off of the corners? Three is linear but if you like a more positive expo feel, you could go to 4 or 5. If it's just a flat feeling motor, some other set-up changes may be in order.
You're going to buy a Tekin?
Can't you keep up with Marcel Pinkster
Updates are free and you can download it from the Tekin site. www.teamtekin.com
15,3 by Richard and still the nr 1 is Marcel.
So soon you can bead them as you have your Tekin
