Tekin RS ESC sensored
Guys. Does anybody know if there is any timing boost if the hotwire is not used? Currently with my es pro,my 17.5 is nit as fast as my previous tc spec.I have turned the throttle profile to the max and neutral width to the least already. Let's just assume the driver remains constant. Does anybody know if there is any timing boost in the original profile?
Haha, funny. I don't have a problem with my driving. I start the race with the fastest car on the track and halfway through an 8 min race the car goes flat and the motor heats up. Battery voltage is never below 3.6 after a race. Also fogot to add what motor im running. DUO 2 17.5
hey randy, chris adams in 17.5 rubber is 4th with a tekin as well
The Timing Advanced is not totally timed.
I don;t no on what setting but it's not on max. I thought 80%.
It sounds like I got to get the hotwire loaded up.
I was looking at the various factory drivers gear ratio. Do you guys happen to know the rationale of gearing at about 6 instad of the recommended 4 for the 17.5 motors. Somebody said that it was to allow the rpm to be higher so that the booster can be on most of the time. Any comments on this?
Good point Bill... I just picked up a RS Pro and had totally forgotten about the setups that were already online. Hopefully will be able to try it out tomorrow.
Gear for the best rip on the infield, use timing on the ESC to get the best speed on the straights.
Thanks Harry for the tip. I will try it when I get my hotwire up
Tekin in the A main by the ETS.
Carsten Madsen is on place 8 in the A final.
