Tamiya TA05MS
#736
how many hits/races before you rebuild your diffs?
Mine lasted up to aprx 15 hits (5mins/race) 20 hits became a little to notchy.
#737
I found this thrust bearing. It's from JAAD Racing and is ceramic nitride. I couldn't find where to buy it on the net though.
http://www.jaadracing.com/
#738
#740
what's the stock ride height in the manual? I tried to set my 05ms at stock settings. what's your ride height in stock setting? My 05ms front ride height is about 2mm and the rear is 5mm. i dont think its normal.
#741
According to Ed (Tryhard) Clarks website Precision RC is the place to go http://www.precisionrc.com. However, I didn't see any reference to the thrust bearing.
Regards
Ed
#742
depends..... I'm running a 3.5 brushless on asphalt with nitro foams.... 5 5min runs tops.... but I have put the JAAD carbon stickers on the pulley on this last rebuild and I've run 6 and it is still smooth!! let's see if I can make 12....
#744
Last sunday we run the car 3 classification rounds and 3 finals. the diff is still ok with the diff cover. last time I've run without it, in the last final the diff felt gritty and not smooth... and Either you have 2 spare diffs, or you don't have time to rebuild it.... I hope I can run at least two race days plus some practice with the covers.... it all depends on how dirt is your track... hehehe
#745
for club racing when i rebuild a diff, i just clean everything, regrease, check the rings, (if worn, flip them over). and adjust it. thats it.
i'm not sure how that is making it expensive?
#746
the rings can be reused many times. I use 400 grit sandpaper to sand the groove off. I put the ring on the diff halve that doesn't have the protrusion on it, then use that as a holder to hold the ring in place as I move it in a circular motion on a piece of 400 grit sand paper on a flat surface. 600 works too. That also gives the diff balls more of a grippable surface so you don't have to tighten your diff as tightly. That puts less stress on your diff balls and thrust bearing.
#747
In the past, I always skipped this part, but this really helps with smooth diff action. Now Im a believer.
#748
what do you do exactly when you rebuild your diff? replace all the parts? i only replace the rings if BOTH sides of the diff rings have a groove already. if i do replace the diff rings, i replace the diff balls also.
#749
lipo will help also when i get back into that. im just waiting until my current nimh packs finally die on me.
can't wait for Sat. BCR! stock here i come. got lots of things to try with my 05MS.
#750
don't use the stock suspension setup... It is very low, as in too low... And yeah, the front is really higher than the rear if you're going to put it on stock manual setup... Always make your starting setup (or point) to 5.5mm rear and 5mm in front... Like what sir al said...
